Edit page settings after creation
Thread begun 1/20/2010 1:36 am by matt360561 | Last modified 1/20/2010 10:01 am by Jason Byrnes | 1475 views | 1 replies |
matt360561
Hi
Once you've used dataAssist to create the results, insert, updae and delete pages, is there anyway you can access the plugin to edit the settings (like irite, you can click on the area, and you have an edit option in the properties area of CS4 to edit the settings). Just wondered it you can do the same with data assist or do you have to delete the pages and recreate each time?
The Individual server behaviors that are added to the pages can be edited.
For example, on the insert page, you can go to the server behaviors panel, Window -> Server Behaviors, and double click on the Insert Record Server behavior to edit how the record is inserted to the database.
