2 sub-menu levels
Thread began 1/20/2010 12:15 am by vwdes71987 | Last modified 1/28/2010 10:20 am by Eric Mittman | 2391 views | 3 replies |
vwdes71987
2 sub-menu levels
Hi, I just started working with the latest version of CSS Menu Builder and wondered if it's possible to use two levels of subnavigation, like:
- Products
--- Product 1
--- Product 2
------ Product 2A
------ Product 2B
------ Product 2C
--- Product 3
--- Product 4
I only get one level (level-1) working...
Thanks for your replies!
Martijn
Yes, you can use multiple levels in your menu. When you edit the contents of the menu you select the level that you would like to add sub links to and click on the plus (+) button. This will create a new link for you in a sub level to the link that was selected.
What steps are you taking and what is the result you are getting?
vwdes71987
Position menu
Ok, the second level seems to work now.... only problem left is its position.
See the attachment to see what I mean. I want the second menu to start at the position of the item it's attached to. So I want "containerkleden" to start at the height of "industrie"... how should I do this?
Thanks in advance!
Martij
This may be a result of the type of menu you are using or customizations you have done to the design. If you add in a default Horizontal Accent type of menu the the sub links will appear next to the link it is associated with, I'm including a screen shot of a basic Accent style menu like this.
