MYSQL Dates
Thread begun 1/19/2010 10:07 pm by nickj | Last modified 1/20/2010 10:24 am by nickj | 2268 views | 4 replies |
nickj
MYSQL Dates
I have a date field which I want to populate with the current date/time and have used <?php echo $current_time = date("m/d/Y H:i:s"); ?> in the past but it doesn't work here?
The field is inserting date into date/time which I would assume is correct.
Nick
MySQL Date Fields like to receive the date in the following format:
yyyy-mm-dd hh:mm:ss
you should use the following code:
<?php echo date("Y-m-d H:i:s"); ?>
If this is on an insert, you can set the default value for the date column to:
NOW()
in the database, this will automatically add the currant date when a record is inserted.
nickj
Thanks, I'll try these.
Where do I set the default column to NOW()?
Nick
In the database.
nickj
ah yes.. never have take advantage of the default column.
