Problem with Menu Links
Thread begun 1/19/2010 9:21 pm by dave.klotz357236 | Last modified 1/20/2010 10:04 am by neilo | 4919 views | 9 replies |
dave.klotz357236
I created a menu on the home page, then just copied this page when creating other pages. I noticed that I had a typo in one of the links so I went ahead and changed it. Now if I go from the home page to the link that it changed it works fine, but if I try and connect to the link from any of the other pages I get a message that says page not found, looking closely I noticed it still had the old name of the link, but when going back in to edit the menu, it shows the correct name.
on other interesting note is if I preview it out of dreamweaver everything works, but only after I upload it to test it on a real server do I get the problem as stated above.
neilo
Hiya Dave,
So when you preview it on your local machine in a browser (F12) all the links work OK? Can you check that all the pages that the menu links to are in the same relative locations on your remote server as they are on in your local site.
Did you move any of the pages after making the menu? If so, did you click 'yes' to update the links?
If the links all work fine in your browser on your local machine, then you could re-upload your pages and CSSMenuWriter folder to your remote server from the Dreamweaver 'Files' Panel.
If you still have problems, could you post back with a link a page with the menu on it?
dave.klotz357236
Still having problems, here is the link
index.html
neilo
Hi Dave,
I see two problems happening, one is that the menu on your 'clients.html' page has a link to 'Clients.html' (with an uppercase 'C') - this needs to be a lowercase 'c'.
The second thing is that there doesn't appear to be a 'contact.html' file in your /ai/ directory on the remote server. Check that the page is there, and that it is called exactly 'contact.html'.
Everything else seems OK from here.
neilo
Hi again Dave,
Just had another look round, - your ai/services.html also links to Clients.html with an uppercase 'C'.
Also, your pages are also linking to menu.css (and ai11.css) and menu.js files in two different locations.
What I think it would be worth doing to get rid of any uncertainty, is re-doing the code between the head tags by replacing what you have on each page with:
<head>
<title>Accelerated Innovators</title>
<link href="ai11.css" rel="stylesheet" type="text/css" />
<script type="text/javascript" src="CSSMenuWriter/cssmw/menu.js"></script>
<style type="text/css" media="all">
@import url("CSSMenuWriter/cssmw/menu.css");
</style>
<!--[if lte IE 6]>
@import url("CSSMenuWriter/cssmw/menu_ie.css");
</style>
<![endif]-->
</head>
and replacing your menu code on each page with:
<ul class="level-0" id="cssmw">
<li><a href="index.html">Home</a></li>
<li><a href="services.html">Services</a></li>
<li><a href="clients.html">Clients</a></li>
<li><a href="about.html">About Us</a></li>
<li><a href="jobs.html">Jobs</a></li>
<li><a href="contact.html">Contact Us</a></li>
</ul>
and make sure that you have your pages (including 'contact.html'), your CSSMenuWriter folder and the ai11.css file all in the same directory.
I like the nice clean style of your design.
dave.klotz357236
Contact page is not created yet
Try this and you will see what I mean,
Go to: index.html
Click on clients you will see the page load, then go back to the home page, click on services, and from the services page go to clients.
for some reason form the home page it reads the correct link clients.html
but if you do to another page it trys the link Clients.html
weird if you ask me
dave.klotz357236
Problem with menu Links
Didn't see your other post, will try that in a few and let you know.
Thank you for the kind words about my design.
neilo
Hi Dave,
Yes, - that's because the homepage clients link is to clients.html, and the services page clients link is to Clients.html.
Browsers when viewing pages 'live' can be fussy about case sensitivity and won't allow wrongly cased links to show, while viewing on your home machine you can often browse the site without any problem.
You may just need to change the clients and services pages links to 'clients' to (lowercase) clients.html.
It is certainly worth getting rid of the duplicate .css & .js paths in the head area though.
Yes - cool design. I like sharp clean layouts!
dave.klotz357236
Ok, everything is cleaned up and working - I think i know where I got into trouble, I was testing another menu design, and renamed the original cssmenuwriter folder, and then renamed it back. Won't do that again!!
Thanks for all your help
neilo
Glad you got it going.
