Changing registration qualifiers
Thread begun 1/19/2010 3:05 pm by laldrich374081 | Last modified 2/22/2010 4:57 pm by Eric Mittman | 10998 views | 26 replies |
laldrich374081
Where can I change the requirement for numbers and special chars in the feilds on the user registration pack? I can see where to change the text that shows up. Can I also just delete some feilds in the user_registration.php file for the user not to fill them in? I am kinda a newbie and can get lost in the code easily.
The User Registration Solution pack works with client and server side validations. If you would like to alter the validations you could do so with the spry validations and using CSS Form Builder or Validation Toolkit.
If you want to remove a particular field on the form you must also remove the validation for that field. Before you delete it look at the blue colored tab around it to identify what spry is applied to it, then go to the bottom of the page and look for that spry. You must delete the spry validation as well as the server side validation that appears at the top of the page.
If you post back with some more details about what specifically you wanting to change and what field to delete I can give you some more detailed steps to take.
laldrich374081
Changing the form
If I delete the Phone# thru the country catagories in the form, what else should I do?
laldrich374081
Also
I would like to make it so any password will work
To remove the phone number from the registration you can just remove the form field:
<input name="UserPhone" type="text" class="WAATKTextField" id="UserPhone" onBlur="if (document.getElementById('PhoneServerValidation')) document.getElementById('PhoneServerValidation').style.display='none';WAValidatePN(document.forms[0].UserPhone,'- Invalid phone number',false,true,'x (xxx) xxx-xxxx',document.forms[0].UserPhone,0,true)" value="<?php echo(ValidatedField("usersRegistration","UserPhone")) ?>" size="32" />
Then you need to remove at least the server side validation:
$WAFV_Errors .= WAValidatePN(((isset($_POST["UserPhone"]))?$_POST["UserPhone"]:"") . "",false,true,true,13);
This will get rid of the field for you. You should also remove the spry validation code for this but it will not be necessary:
var sprytextfield4 = new Spry.Widget.ValidationTextField("sprytextfield4", "none", {validateOn:["blur"], minChars:7, maxChars:20});
Please describe exactly how you would like to make it so that any password works. The way the user registration currently works is to have a user register with username, password and other details. When the user returns to the site they must enter the same username and password they used to register to login to the site. Please describe how you would like it to work differently.
laldrich374081
Password
currently the password requires 6 chars at least 1 number and 1 letter this is what I would like to change to maybe 5 chars any chars letters or numbers.
The first thing you would want to adjust for this is the spry validation for the password. Toward the bottom of the page is this line of code:
var sprypassword1 = new Spry.Widget.ValidationPassword("sprypassword1", {validateOn:["blur"], minChars:6, minNumbers:1, minAlphaChars:1});
It is the three parameters in here that control the character length and type of chars:
You can change the min chars to be whatever you want, then for the other two you can just delete them so in the end it would look like this:
var sprypassword1 = new Spry.Widget.ValidationPassword("sprypassword1", {validateOn:["blur"], minChars:5});
Next you would want to update the server side validations that are enforcing these rules. This is controlled by these three lines of code toward the top of the page:
$WAFV_Errors .= WAValidateEL(((isset($_POST["UserPassword"]))?$_POST["UserPassword"]:"") . "",6,50,true,3);
$WAFV_Errors .= WAValidateRX(((isset($_POST["UserPassword"]))?$_POST["UserPassword"]:"") . "","/[0-9]/",true,4);
$WAFV_Errors .= WAValidateRX(((isset($_POST["UserPassword"]))?$_POST["UserPassword"]:"") . "","/[a-z,A-Z]/",true,5);
The first one is checking the length and the next two are checking the type of chars. You can update the first to be a 5 instead of 6 then delete the next two, this would look like this:
$WAFV_Errors .= WAValidateEL(((isset($_POST["UserPassword"]))?$_POST["UserPassword"]:"") . "",5,50,true,3);
laldrich374081
Thanks Eric I will give this a try!!
Let us know if have any other questions about this or come across any problems.
laldrich374081
Hi Eric
I tried these and everything seems ok but now it stopped sending the validation code via email. I don't think that i changed any the in any other files. Where can I look. You can look at aldrichphotos.com
