Eway XML Error for Rebill
Thread began 1/19/2010 2:03 pm by jo4koalas392067 | Last modified 1/20/2010 7:42 pm by jo4koalas392067 | 1785 views | 2 replies |
jo4koalas392067
Hi
I am trying to set up my payment gateway with Eway for Rebilling (reoccuring payments). The following is a sample of what they need to receive in order to do this:
<RebillUpload>
<NewRebill>
<eWayCustomerID>87654321</eWayCustomerID>
<Customer>
<CustomerRef>Ref123</CustomerRef>
<CustomerTitle>Mr</CustomerTitle>
<CustomerFirstName>Joe</CustomerFirstName>
<CustomerLastName>Bloggs</CustomerLastName>
<CustomerCompany>Bloggs Enterprises</CustomerCompany>
<CustomerJobDesc>CEO</CustomerJobDesc>
<CustomerEmail>joe@bloggs.com.au</CustomerEmail>
<CustomerAddress>123 Bloggs St</CustomerAddress>
<CustomerSuburb>Capital City</CustomerSuburb>
<CustomerState>ACT</CustomerState>
<CustomerPostCode>2600</CustomerPostCode>
<CustomerCountry>Australia</CustomerCountry>
<CustomerPhone1>0299995555</CustomerPhone1>
<CustomerPhone2>0255559999</CustomerPhone2>
<CustomerFax>0255995599</CustomerFax>
<CustomerURL>www.bloggs.com</CustomerURL>
<CustomerComments>Please ship ASAP</CustomerComments>
</Customer>
<RebillEvent>
<RebillInvRef>ref123654</RebillInvRef>
<RebillInvDesc>Joe Bloggs reBILLing</RebillInvDesc>
<RebillCCName>MR J Bloggs</RebillCCName>
<RebillCCNumber>44444333322221111</RebillCCNumber>
<RebillCCExpMonth>10</RebillCCExpMonth>
<RebillCCExpYear>06</RebillCCExpYear>
<RebillInitAmt>0</RebillInitAmt>
<RebillInitDate>29/04/2002</RebillInitDate>
<RebillRecurAmt>5</RebillRecurAmt>
<RebillStartDate>18/06/2005</RebillStartDate>
<RebillInterval>2</RebillInterval>
<RebillIntervalType>2</RebillIntervalType>
<RebillEndDate>18/07/2006</RebillEndDate>
</RebillEvent>
</NewRebill>
</RebillUpload>
More information on this can be found at: PaymentsRebill.aspx
Unfortunately I have modified my files and cannot get it work; no values are sent through (see XML capture). I have attached the relevant files and wonder if someone can have a look to see where I am going wrong as Eway can't help me as they say it is a problem with my XML coding which I have just modified from Web Assist.
Many thanks.
XMLcapture.zip
confirm.zip
eWAY_XML_PHP.zip
this part of the eWAY_XML_PHP.php file:
for ($x=0; $x<count($reqArray[0]); $x++)  {
    $varvalueArray[strtolower($reqArray[0][$x])] = $reqArray[1][$x];
  for ($x=0; $x<count($optArray[0]); $x++)  {
    $varvalueArray[strtolower($optArray[0][$x])] = $optArray[1][$x];
  for ($x=0; $x<2; $x++)  {
    $varvalueArray[strtolower($itemArray[0][$x])] = $itemArray[1][$x];
is creating a supper array out of the $reqArray, $optArray and $itemArray array's that are created on the confirm page.
This code:
is used to convert the name used for the array piece on the confirm page to lower case. So the name of each array piece is the lower case version of the name created on the confirm page.
When you are building up the xml, you need to refer to each array piece using the all lower case name.
in other words:
"<eWayCustomerID>" . $varvalueArray["eWayCustomerID"] . "</eWayCustomerID>".
should be:
"<eWayCustomerID>" . $varvalueArray["ewaycustomerid"] . "</eWayCustomerID>".
you can verify the correct names to with this code:
<?php var_dump($varvalueArray); ?>
jo4koalas392067
Thank you Jason, for explaining this. I Have altered the text case and all working fine.
You are a star yet again.
Jo
