Unable to browse server in test environment
Thread begun 1/19/2010 6:36 am by edison390711 | Last modified 1/22/2010 5:37 pm by Jimmy Wu | 4502 views | 7 replies |
edison390711
My test php environment is set up using XAMPP on my local computer. I can use the Insert/Edit Image icon in PowerCMS to upload and edit images, but the Browse Server buttons do not work. I get the following message:
Fatal error: Call to undefined method MDB2_Error::fetchAll() in E:\Program Files (x86)\Xampp\htdocs\CMS\HTMLEditor\editor\plugins\kfm\includes\db.php on line 43
This Browse Server buttons work fine on my production server.
Any ideas about what is happening?
Jimmy Wu
It looks like you're missing the php-mdb2-driver-mysql package on your local server. You will have to install this to get rid of that error.
edison390711
Thanks for the info.
I tried installing MDB2_Driver_mysql and MDB2_Driver_sqlite versions 1.4.1 and the problem still occurs. Are these not the correct drivers? The documentation for these updates isn't easy to follow.
Jimmy Wu
Is this the one you installed?
MDB2_Driver_mysql
This is where I found the original issue:
88
Do you have pear installed?
It looks like the ones you've installed are the correct ones.
edison390711
I'm running pear 1.7.2.
Every time I run a pear command, I get the following PHP error message from Windows:
Invalid Configuration Directive
Jimmy Wu
Looking on the PEAR forums, I found this thread:
topic2044.html
It looks like this person resolved the issue with a re-install of the latest version of PHP.
As far as any PEAR errors, it may be best to ask in that forum, since it is specific for PEAR support.
edison390711
Upgrading PHP resolved the problem.
Thanks!
Jimmy Wu
Great to hear that. If you run into any additional issues, feel free to open a new thread.
