$_FILES['Filedata']['tmp_name']
Thread begun 1/18/2010 9:48 pm by info315909 | Last modified 1/19/2010 4:30 pm by Jason Byrnes | 7027 views | 3 replies |
info315909
My issue is related to uploading an image via a Flash frontend to a php script. Currently the process is working correctly in a simplified manner. The swf file will post the user selected image to a php file which contains the following simple code:
//create the directory if doesn't exists (should have write permissons)
if(!is_dir("./files")) mkdir("./files", 0755);
//move the uploaded file
move_uploaded_file($_FILES['Filedata']['tmp_name'], "./files/".$_FILES['Filedata']['name']);
chmod("./files/".$_FILES['Filedata']['name'], 0777);
However, I have been trying to replace this simple php function above with a Digital File Pro 2 Upload File function. I would like to get a DFP2 Upload Function working off the $_FILES['Filedata']['tmp_name'] value instead of the usual form field value such as the script above does.
In my testing to date, I have not been able to get DFP2 to accept $_FILES['Filedata']['tmp_name'] as the filefield to work with. Have tried feeding the value via a session value as well as a hidden form field value - but no luck.
Any help will be greatly appreciated. Thanks in advance.
Digital file pro will not be able to use that value, you must specify the name of the file filed instead.
info315909
In that case, is there a method for using Digital File Pro 2 with images already stored on the server? Move, rename and resize an image already on the server?
No, digital file pro cannot be used for moving / resizing images that already exist on the server, only for images being uploaded from a client computer to the server.
