Bullet Alignment Issue
Thread begun 1/18/2010 7:16 pm by info355813 | Last modified 1/20/2010 2:53 pm by info355813 | 2064 views | 2 replies |
info355813
I have a site put together using some webassist products and I'm using PowerCMS. The site isn't completely done but I'm having a problem with bullets aligning correct with other text. I'm sure it's something easy but I can't seem to figure out why.
You'll need the username: admin & password: 111111 to view the site.
a/ - uses numbers as bullets, formatted in power CMS
services.php - uses normal bullets formatted in power CMS
you'll notice the bullets are aligned outside of all the other text instead of in. maybe it's a css issue I couldn't figure out. any help would be great. thanks.
MickW
You have..
margin : 0;
padding : 0;
at the top of your css - this zeros the default margins that are present in the UL tag.
You need to add a left margin move the UL to the right:
table ul {
margin-left : 10px;
HTH
Mick
info355813
thank you very much
