eCart
Thread begun 1/18/2010 3:33 pm by info398618 | Last modified 1/19/2010 9:22 am by Jason Byrnes | 2680 views | 3 replies |
info398618
eCart
Hello, how do I delete/edit a checkout process? I want to put in a different payment gateway. Thnx
You will need to delete the checkout pages that where created by the checkout wizard, they will usually be:
checkout.php
confirm.php
pp_confirm.php
checkout_success.php
checkout_failure.php
pp_checkout_success.php
pp_checkout_failure.php
shipping_failure.php
info398618
Fatal error
After I put in the checkout process, I get this error:
Fatal error: Call to a member function GetContent() on a non-object in C:\xampp\htdocs\confirm.php on line 7
Line 7 has the folowing code:
$guardianprotectionsource->GetContent()
guardianprotectionsource is the name of the site folder in htdocs. Thanks.
This error occurs if you have named the eCart object the same as another application object. Usually, it is the connection object. Make sure you use unique names for all application objects such as the eCart object, connection and recordsets.
