eCart 5compatibility
Thread begun 1/18/2010 3:32 pm by b.doherty278976 | Last modified 1/19/2010 8:08 am by b.doherty278976 | 2281 views | 2 replies |
b.doherty278976
I have been using eCart 4.xx for quite a while and have developed sites for many clients. If I do upgrate to 5.xx (which sounds otherwise like a very good idea), how far do I have to bend over backwards to support my current clients.
In other words - can I edit the eCart 4.xx sites after I install version 5 without having to redo those sites?
As long as the previous sites are using PHP, eCart 5 will work without a problem.
If you have ASP or ColdFusion sites, you will need to use eCart to maintain them. If this is the case, you should create a secondary computer user, give this user administrative privileges, and install eCart 4 under this user. you will also need to recreate the site definitions in Dreamweaver under the second user. When you need to modify one of these site, log out of the primary user, and into the secondary user to use eCart 4.
b.doherty278976
Thanks for the info.
I was a little worried because I have had problems between various minor versions. They seem to have gone away after I resaved the cart, but it took a while to figure that out.
