DB insert action removed!!!!!
Thread begun 1/18/2010 1:07 pm by mrs | Last modified 1/20/2010 2:28 pm by mrs | 5627 views | 10 replies |
mrs
Hi, I have just applied the form builder to an existing form only to find that the database insert action of my form is no longer working. It was working fine before hand!
What has gone wrong?
I have also added captcha to the form, but for some reason the I can enter any code and the validation accepts it!!
And consistently during use, form builder crashes Dreamweaver!
Please help me.
Validation is set to trigger on a form element that sdoes not exist, change line 6:
if (isset($_POST["Default_submit"])  && !isset($_GET["invalid"]))  {
if (isset($_POST["AspectBOC_submit"])  && !isset($_GET["invalid"]))  {
the insert server behavior is also set to trigger on an element that does not exist. change line 30:
if (isset($_POST["Insert"])) // Trigger
if (isset($_POST["AspectBOC_submit"])) // Trigger
mrs
OK, I'll have a look at that, but why should it change when it was working in the first place? The use of the form extension has broken it in some way, so is that something I have done wrong, or is that something just happens and can't be helped?
I can understand why the insert has changed to a degree, but the validation was set up using the form extension, so during the processing and creation of the form, it has changed the trigger.
Now I have said it, the insert behaviour was created with data assist, so is the change due to an unforeseen incompatibility between the two extensions, or is it something I have missed again?
Thanks.
mrs
Neither of those changes worked... the insert failed again, and the captcha validation failed again too!
I am sorry to say that I need this sorted ASAP as it is an online book of condolences for a client who had one of their directors die at the weekend, so I really would like to get some form of validation put up so I can protect against spam bots etc as what is being inserted is instantly visible to the public that know the link. People are waiting to pay their respects so the pressure is really on me :o(
Thanks.
mrs
Are you able to help me with the issues that I am having trouble with?
The forms action has been changed to post to the bocResults.php page, this will bypass the validation that has been applied.
change:
html:
<form class="NewFromBlank_Default" id="AspectBOC_NewFromBlank_Default" name="AspectBOC_NewFromBlank_Default" method="post" action="bocResults.php">
html:
<form class="NewFromBlank_Default" id="AspectBOC_NewFromBlank_Default" name="AspectBOC_NewFromBlank_Default" method="post" action="">
mrs
Sorry, still didn't work!
I have made the changes suggested so far, but it still hasn't validated the captcha box by matching the input text with that of the image, and it hasn't subsequently entered into the database either.
Have you got any other thoughts?
Thanks thus far.
please send the latest copy of your page
mrs
Here you go. I have also added associated files created by form builder and data assist to see if something is broken there.
I have created a support ticket so we can look into this further. to view and edit your support incident, please log into your support history:
supporthistory.php?
