Digital File Pro not working
Thread begun 1/18/2010 7:31 am by info307537 | Last modified 1/19/2010 9:30 am by Jason Byrnes | 2042 views | 3 replies |
info307537
I have created the following page using Digital File Pro: apply_upload.php
I have tested it and it worked fine for me using most common browsers, but I have getting lots of emails from various users just saying that it doesn't work and they say the page just goes blank when submitted.
Do you have any idea's why?
I have attached the code for the page as a txt file as your system does not allow me upload php files.
When a page loads blank, it means a php error has occurred but error reporting is turned. To find out what the error is, you can add the following at line 1 to turn error reporting on:
error_reporting
(E_ALL);
once we know the error, we can probably find the cause very quickly.
info307537
Correction
Sorry the page did not go blank it just didn't redirect the thank you page or send the confirmation email. Instead it just refreshed the current page.
Any idea's why this would happen as I can't replicate the issue. Could it be down to broadband speeds? Each file was below 2MB.
most likely, validatuion is failing,
To see if this is the case, change the following code:
if ($WAFV_Errors != "")  {
    PostResult($WAFV_Redirect,$WAFV_Errors,"apply");
    die($WAFV_Errors);
if validation fails, it will write a comma separated list of numbers to the screen, post the results back with your reply.
