Password Change not working
Thread begun 1/18/2010 7:05 am by dan377928 | Last modified 1/22/2010 12:29 pm by dan377928 | 2155 views | 4 replies |
dan377928
I have installed the password change option exactly as the Tutorial instructed. However when you change your password there are no errors but the database does not update.
1) Your change password form element has a space in the name, you cannot have spaces in the name of form elements:
<input type="text" name="Change Password" id="Change Password" />
change that to remove the space:
<input type="text" name="ChangePassword" id="ChangePassword" />
2) try adding the following at line 1 of the page:
<?php if(!session_id()) session_start(); ?>
dan377928
After making the changes you suggested the password field in the database now gets updated but it is empty.
1) you password field has a space in the name:
it should be:
2) In the update record behavior, you have bound the password column to the FILES collection:
$WA_fieldValuesStr = "".((isset($_FILES["Change"]))?$_FILES["Change"][""]:"") ."";
instead of the POST Collection:
$WA_fieldValuesStr = "".((isset($_POST["ChangePassword"]))?$_POST["ChangePassword"]:"") ."";
dan377928
Thanks that did it.
The security assist wizard created the update record behavior. I did not change this or see where i could have made a choice that would have changed it.
