Z-index
Thread begun 1/18/2010 6:13 am by rainiedey397358 | Last modified 1/18/2010 11:42 am by Jason Byrnes | 1677 views | 1 replies |
rainiedey397358
Z-index
I need to change how the menu appears (under) the overlay used with Bumpbox. How can I change the z-index so the menu is below/under the overlay?
Thanks!!!
Rainie dey
in the menu.css file, edit the first style:
ul#cssmw0 {
cursor: default;
list-style-type: none;
margin: 0 0 0 0;
padding: 0 0 0 0;
to use a z-index:
ul#cssmw0 {
cursor: default;
margin: 0 0 0 0;
padding: 0 0 0 0;
position: relative;
z-index:1;
then set the bumpbox div to have a higher z-index:
.Bumpbox {
position: relative;
z-index: 2;
When setting a z-index, you must also specify a position, each position has a separate z-index.
