warning: Mail(): SMTP server response issue
Thread begun 1/18/2010 4:01 am by info383269 | Last modified 2/08/2010 2:49 pm by Eric Mittman | 7675 views | 11 replies |
info383269
Hello,
I copied the data over to my site and tried to run it for a test only. Once the form is submitted I get the blank form again with the following message on top of the form:
Warning: mail(): SMTP server response: 451 See smtplf.html. in D:\iftpsvc\lightning\www\WA_Universal_Email\mail_PHP.php on line 254
Warning: Cannot modify header information - headers already sent by (output started at D:\iftpsvc\lightning\www\WA_Universal_Email\mail_PHP.php:254) in D:\iftpsvc\lightning\www\contactus.php on line 35
Could you please advise on what to do? The site where I installed the form is:
contactus.php
Kind regards
Jurg
Office Guy-172461
Have a look here:
Solving the "headers already sent" problem
148/
Are you using the Contact Form Solution pack?
If so, take a look at the WA_UniversalEmail/Templates/contactus.php file.
look for the following line:
<?php echo(str_replace("\n","<BR />",$pval)); ?>
and change it to:
<?php echo(str_replace("\r\n","<BR />",$pval)); ?>
Office Guy,
When a PHP warning occurs, it does not stop the page from processing, it just displays the error, and continues along processing the rest of the code on the page.
In the case, the output that is causing the headers already sent error to occur, is the Warning.
When the Headers Already sent error is proceeded by another warning error message, it should be ignored.
info383269
Problems with forms
Hi there,
thanks for your assistance, unfortunately nothing seems to make any difference. I copied the original files as well and made only the changes required but even this does not work.
Yes I am using the contact form solution pack that I purchased yesterday. I modified the source code in WA_UniversalEmail/Templates/contactus.php file as well and still nothing.
Anything else I can try, I was under the impression that this is a ready to go product and I have now spent hours for something that should take minutes!!
Thanks for your help, looking forward to a solution,
Kind regards
Jurg
In the WA_UniversalEmail/mail_PHP.php file, change line 114:
$lineEnd = "\n";
$lineEnd = "\r\n";
info383269
Form error message
Thanks for this, this has now removed one error message. I still get this message:
Fatal error: Call to undefined function: waue_definition() in D:\iftpsvc\lightning\www\WA_Universal_Email\WAUE_contact_1.php on line 15
Any idea on how I can fix this? Sorry to be a pain but this extension is not easy to configure and get sorted.
Kind regards
Jurg
make sure the contact us page has the following code near line 1:
<?php require_once("WA_Universal_Email/mail_PHP.php"); ?>
info383269
Form error message
Thanks Jason,
unfortunately still no success with this form. Now I get the following initial error message when loading the page contactus.php
Warning: session_start(): Cannot send session cookie - headers already sent by (output started at D:\iftpsvc\lightning\www\contactus.php:2) in D:\iftpsvc\lightning\www\WA_ValidationToolkit\WAVT_ValidatedForm_PHP.php on line 3
Warning: session_start(): Cannot send session cache limiter - headers already sent (output started at D:\iftpsvc\lightning\www\contactus.php:2) in D:\iftpsvc\lightning\www\WA_ValidationToolkit\WAVT_ValidatedForm_PHP.php on line 3
After I process the form on this page I still get the following error message:
Can I please have it fixed or the money back, I am wasting my time with this and I do not get paid for this by my customers.
From what you are reporting it seems that there are two problems occurring. The first problem seems to be that there is some output occurring on line 2 of contactus.php. This is likely from some white space that is present on or near this line. Getting rid of the output that is specified should get you past the error about the headers.
As for the definition error this function is defined in the WA_Universal_Email > mail_PHP.php file. So long as the include reference is present for this file and the file is in this folder on the server you should not get this error.
I have opened a ticket for you on this issue so that we can exchange files and some more details. To update the ticket please login to WebAssist.com and visit your support history.
You updated the ticket to say that the issue with the output already started has been resolved. The other issue you are experiencing with the undefined function seems to be a code order issue that has occurred on the page. So long and the mail and mail formatting includes appear before the Universal Email server behavior code you should not have this problem.
