Data Assist: Search by URL String
Thread begun 1/18/2010 3:52 am by jwhite210077 | Last modified 1/18/2010 1:58 pm by Jason Byrnes | 1690 views | 1 replies |
jwhite210077
The search feature works perfect out of the box, but I am wondering if in addition to searching from the form/text field...if I can set it up to search by the url string too (i.e. results.php?keywords=searchterm).
First, on the bindings panel, click the plus button and select URL variable to add the dynamic binding.
Then in the data assist search wizard, you will need to set the trigger to before page load, you can then add a new search criteria using the query string variable.
