results pages
Thread begun 1/17/2010 5:15 am by steve.tucker253175 | Last modified 1/18/2010 12:12 pm by steve.tucker253175 | 1708 views | 2 replies |
steve.tucker253175
results pages
I have run the data assist wizard and have created a set of pages based on a single table and I have added menu items to record foreign keys of code tables in the update and insert pages.
But I must be missing the obvious because I cannot see how to change the results page to return a text value from my code table instead of the FK storded in the data base.
using the wizard the following SQL is generated
SELECT IP_SNAPSHOT_TABLE.ID,
IP_SNAPSHOT_TABLE.SSI_TABLE_NAME,
IP_SNAPSHOT_TABLE.SSI_SS_DESTINATION
FROM IP_SNAPSHOT_TABLE
However I want to return the text description from the code table not the FK
I have tried updating the SQL directly but this produces an error.
IP_SNAPSHOT_TABLE.SSI_SS_DESTINATION,
IP_DESTINATIONS.DEST_NAME
FROM IP_SNAPSHOT_TABLE INNER JOIN
IP_DESTINATIONS ON IP_SNAPSHOT_TABLE.SSI_SS_DESTINATION =
IP_DESTINATIONS.ID
This is such a simple thing to do I must be missing the obvious, can anyone help?
You will need to modify the SQL To use an INNER JOIN like you have tried.
You say the SQL You are using produces an error, but dont specify what the error is.
Can you let us know what the error message is?
steve.tucker253175
Thanks Jason
I have sorted my issue in the code but I just thought there would be an option to do this in the wizard.
Thanks for putting my mind to rest.
For anyone else experiencing this issue. You can also create a view in the database and run the wizard with this as the table of focus.
Backed up the result page.
Re-run the wizard for the real table.
Replace the results page.
