File list Recordset
Dose Webassist have anything comparable the the ADDT Record List Record Set? I want to display a list of files in a folder on the server.
Unfortunately, we do not have anything that will list the files within a folder. What you would have to do is to insert the filename into a database each time you upload a file into the directory and delete the filename from the database when you delete the file. Then you can create a recordset that will display the filenames.
