add to cart error
Thread begun 1/16/2010 11:30 am by jack279078 | Last modified 1/19/2010 10:39 am by Eric Mittman | 2580 views | 3 replies |
jack279078
add to cart error
When you click "add to cart" button from the product_detail page
http://outdoorlightingfixturesonline.com//Products_Detail.php?ProductID=610
The link is incorrect, I believe. At least the page won't load.
http://products_detail.php/?ProductID=610
Now what is really confusing me is if I add the first item
http://outdoorlightingfixturesonline.com/Products_Detail.php?ProductID=110
Then all other links work and the button directs to
http://outdoorlightingfixturesonline.com/cart.php
Does anyone have an idea of how I to do this and a correction for the issue?
Thank you
In the link that you posted where things are not working correctly there is an extra slash (/) present in the link:
html:
When I try this same link without the extra slash it seems to be working ok for me:
html:
http://outdoorlightingfixturesonline.com/Products_Detail.php?ProductID=610
It seems that you may have an extra slash present in your root URL setting in your globals file, if you remove the trailing slash it should fix this issue for you.
jack279078
You guys are good. I spent hours not seeing the obvious. Iam using this definition for the site now
$WAGLOBAL_Root_URL = "http://outdoorlightingfixturesonline.com" ;
$WAGLOBAL_Site_Name = "Barn House Lighting" ;
$WAGLOBAL_Address = "503 Suncook Valley Road (Route 28)";
$WAGLOBAL_City = "Alton";
$WAGLOBAL_State = "NH";
$WAGLOBAL_Zip = "03809";
$WAGLOBAL_Country = "US";
$WAGLOBAL_GoogleAPIKey = "ABQIAAAAXafbUiGiRYj0bogExLhVCRT2yXp_ZAY8_ufC3CFXhHIE1NvwkxT5czkOfeMRZCjwJ7_QG4gFmJ1OGQ";
$WAGLOBAL_localRoot = "/powerstore/";
$WAGLOBAL_remoteRoot = "http://outdoorlightingfixturesonline.com/" ;
It seems to be working. on enother site I define it this way with good results
$WAGLOBAL_Root_URL = "http://lamppostsonline.com/" ;
$WAGLOBAL_Site_Name = "Lamp Posts" ;
$WAGLOBAL_Address = "503 Suncook Valley Road";
$WAGLOBAL_GoogleAPIKey = "ABQIAAAApNJMBVqTludfPvhD1wHWixSOiLRtrAVDomgxe0iJKHDP3oS-_hTob9_J0SQQtl-mHrKUDKbawyXSFw";
$WAGLOBAL_localRoot = "/";
$WAGLOBAL_remoteRoot = "/";
Any clue to why the difference?
Also thank you web assist support has been great!
You might see a difference with these setting based on the remote root setting. The slash is probably translating to the site root URL properly. If you have them setup like this and have tested to confirm that they are both working properly then it seems that it is fine.
