Contactus.php form is not sending form data
Thread begun 1/15/2010 11:53 pm by edgar294281 | Last modified 4/12/2010 9:53 am by i.edwards384429 | 15107 views | 21 replies |
edgar294281
I've installed the contact form solution pack. I got the form placed into an exiting webpage and uploaded it on the web server. The form looks great but is not sending anything. I click the submit button and nothing happens. The information that were placed in the form resets.
Question?
1. Do I need to give the contactus.php a "form Action" or leave it blank?
Can someone provide solutions.
EP
No, the action of the form should be left blank.
For the contact form to function you need to make sure you have copied all of the needed code from the original contactus.php page to your existing page.
There are three code chunks you need:
1) All of the code from line 1 of the contactus.php page until the <doctype...> tag:
<?php require_once('WA_Globals/WA_Globals.php');?>
require_once("WA_ValidationToolkit/WAVT_Scripts_PHP.php"); ?>
require_once("WA_ValidationToolkit/WAVT_ValidatedForm_PHP.php"); ?>
require_once("WA_Universal_Email/mail_PHP.php"); ?>
require_once("WA_Universal_Email/MailFormatting_PHP.php"); ?>
if ($_SERVER["REQUEST_METHOD"] == "POST")  {
$WAFV_Redirect = "";
$_SESSION['WAVT_contact_Errors'] = "";
  if (
$WAFV_Redirect == "")  {
$WAFV_Redirect = $_SERVER["PHP_SELF"];
$WAFV_Errors = "";
$WAFV_Errors .= WAValidateRQ(((isset($_POST["Contact_Name"]))?$_POST["Contact_Name"]:"") . "",true,1);
$WAFV_Errors .= WAValidateEM(((isset($_POST["Email_address"]))?$_POST["Email_address"]:"") . "",true,2);
$WAFV_Errors .= WAValidateRQ(((isset($_POST["Comments"]))?$_POST["Comments"]:"") . "",true,3);
$WAFV_Errors .= WAValidateLE(((isset($_POST["Security_code"]))?strtolower($_POST["Security_code"]):"") . "",((isset($_SESSION["captcha_1"]))?strtolower($_SESSION["captcha_1"]):"") . "",true,4);
$WAFV_Errors .= WAValidateLE(((isset($_POST["Security_question"]))?strtolower($_POST["Security_question"]):"") . "",((isset($_SESSION["random_answer"]))?strtolower($_SESSION["random_answer"]):"") . "",true,5);
$WAFV_Errors .= WAValidateRX(((isset($_POST["addblock"]))?$_POST["addblock"]:"") . "","/^$/i",false,6);
$WAFV_Errors .= WAValidateRX(((isset($_POST["seconddblock"]))?$_POST["seconddblock"]:"") . "","/^$/i",false,7);
  if (
$WAFV_Errors != "")  {
PostResult($WAFV_Redirect,$WAFV_Errors,"contact");
if ((($_SERVER["REQUEST_METHOD"] == "POST") && (isset($_SERVER["HTTP_REFERER"]) && strpos(urldecode($_SERVER["HTTP_REFERER"]), urldecode($_SERVER["SERVER_NAME"].$_SERVER["PHP_SELF"])) > 0) && isset($_POST)))     {
//WA Universal Email object="mail"
  //Send Loop Once Per Entry
$RecipientEmail = "".($WAGLOBAL_Contact_Email_To)  ."";include("WA_Universal_Email/WAUE_contact_1.php");
//Send Mail All Entries
if ("index.php"!="")     {
header("Location: thankyou.php");
2) in the head, you need to copy the spry assets code:
<script  src="SpryAssets/SpryValidationTextField.js" type="text/javascript"></script>
<script  src="SpryAssets/SpryValidationTextarea.js" type="text/javascript"></script>
<style>
.textfieldServerError {
  display:block;
  margin:0px;
  color:#CC3333;
  border: 1px solid #CC3333;
</style>
<link href="SpryAssets/SpryValidationTextField.css" rel="stylesheet" type="text/css" />
<link href="SpryAssets/SpryValidationTextarea.css" rel="stylesheet" type="text/css" />
in the body, you need to copy the entire form, including the spry init code:
<form  action="" method="post" name="emailContact" id="emailContact" onsubmit="">
  <div style="width:100%">
    <label for="Contact_Name" >Your name:</label>
    <br />
    <span id="sprytextfield1">
    <input name="Contact_Name" type="text" class="inputValue" id="Contact_Name" onblur="if (document.getElementById('nameServerError')) document.getElementById('nameServerError').style.display='none'" value="<?php echo(ValidatedField("contact","Contact_Name")) ?>" />
    <span class="textfieldRequiredMsg">A value is required.</span></span>
    <input name="addblock" type="text" id="addblock" style="display:none" value="" />
if (ValidatedField("contact","contact"))  {
  if ((
strpos((",".ValidatedField("contact","contact").","), "," . "1" . ",") !== false || "1" == ""))  {
    if (!(
false))  {
    <span id="nameServerError" class="textfieldServerError">Please provide your name.</span>
    <?php //WAFV_Conditional contact.php contact(1:)
    <br />
    <label for="Email_address" >E-mail address:</label>
    <br />
    <span id="sprytextfield2">
    <input name="Email_address" type="text" class="inputValue" id="Email_address" onblur="if (document.getElementById('emailServerError')) document.getElementById('emailServerError').style.display='none'" value="<?php echo(ValidatedField("contact","Email_address")) ?>" />
    <span class="textfieldRequiredMsg">A value is required.</span><span class="textfieldInvalidFormatMsg">Invalid format.</span></span>
    <input name="seconddblock" id="seconddblock" type="text" style="display:none" value="" />
  if ((
strpos((",".ValidatedField("contact","contact").","), "," . "2" . ",") !== false || "2" == ""))  {
    if (!(
false))  {
    <span id="emailServerError" class="textfieldServerError">Please provide your email addess so we can get back in touch with you.</span>
    <?php //WAFV_Conditional contact.php contact(2:)
    <br />
    <label for="Comments" >Comments:</label>
    <br />
    <span id="sprytextarea1">
    <textarea name="Comments" class="inputText" id="Comments" onblur="if (document.getElementById('commentsServerError')) document.getElementById('commentsServerError').style.display='none'" ><?php echo(ValidatedField("contact","Comments")) ?></textarea>
    <span class="textareaRequiredMsg">A value is required.</span></span>
  if ((
strpos((",".ValidatedField("contact","contact").","), "," . "3" . ",") !== false || "3" == ""))  {
    if (!(
false))  {
    <span id="commentsServerError" class="textfieldServerError">Please let us know how we can assist you.<br />
    </span>
    <?php //WAFV_Conditional contact.php contact(3:)
    <label for="Security_code" ><br />
    Security code:</label>
    <br />
    <img  src="WA_ValidationToolkit/WAVT_CaptchaSecurityImages.php?noisecolor=<?php echo $WAGLOBAL_Captcha_Noise; ?>&bgcolor=<?php echo $WAGLOBAL_Captcha_BG; ?>&textcolor=<?php echo $WAGLOBAL_Captcha_Text; ?>&transparent=<?php echo $WAGLOBAL_Captcha_BG_transparent; ?>&characters=<?php echo $WAGLOBAL_Captcha_Characters; ?>&width=<?php echo $WAGLOBAL_Captcha_Width; ?>&height=<?php echo $WAGLOBAL_Captcha_Height; ?>&font=<?php echo $WAGLOBAL_Captcha_Font; ?>" alt="security code" /><br  />
    <span id="sprytextfield3">
    <input name="Security_code" type="text" class="inputValue" id="Security_code" onblur="if (document.getElementById('captchaServerError')) document.getElementById('captchaServerError').style.display='none'" maxlength="40" />
    <span class="textfieldRequiredMsg">A value is required.</span><span class="textfieldMinCharsMsg">Minimum number of characters not met.</span><span class="textfieldMaxCharsMsg">Exceeded maximum number of characters.</span></span>
  if ((
strpos((",".ValidatedField("contact","contact").","), "," . "4" . ",") !== false || "4" == ""))  {
    if (!(
false))  {
    <span id="captchaServerError" class="textfieldServerError">Your security code entry did not match the image.</span>
    <?php //WAFV_Conditional contact.php contact(4:)
    <br />
      <?php require_once("WA_ValidationToolkit/WAVT_CaptchaSecurityQuestion.php"); ?>
    </label>
    <br />
    <span id="sprytextfield4">
    <input name="Security_question" type="text" class="inputValue" id="Security_question" onblur="if (document.getElementById('securityServerError')) document.getElementById('securityServerError').style.display='none'" maxlength="40" />
  if ((
strpos((",".ValidatedField("contact","contact").","), "," . "5" . ",") !== false || "5" == ""))  {
    if (!(
false))  {
    <span id="securityServerError" class="textfieldServerError">Your answer was not correct.</span>
    <br />
    <input type="submit" value="Submit" class="inputButton"/>
  </div>
</form>
<script type="text/javascript">
var sprytextfield1 = new Spry.Widget.ValidationTextField("sprytextfield1", "none", {validateOn:["blur"]});
var sprytextfield2 = new Spry.Widget.ValidationTextField("sprytextfield2", "email", {validateOn:["blur"]});
var sprytextarea1 = new Spry.Widget.ValidationTextarea("sprytextarea1", {validateOn:["blur"]});
var sprytextfield3 = new Spry.Widget.ValidationTextField("sprytextfield3", "none", {validateOn:["blur"], minChars:<?php echo $WAGLOBAL_Captcha_Characters; ?>, maxChars:<?php echo $WAGLOBAL_Captcha_Characters; ?>});
var sprytextfield4 = new Spry.Widget.ValidationTextField("sprytextfield4", "none", {validateOn:["blur"]});
</script>
Make sure you dont change the names of any of the form elements. Also, if you remove any of them, you will need to remove the code that validates that form element.
edgar294281
Contactus form not working
Thank for providing us with this information. I will try this today.
What is strange....We did not remove any code. This is the same file that was downloaded from Webassist. Can you check and verify. We need to know because if we need to download a fresh copy it would be a bad copy.
Edgar
I'm confused. In your initial question you say:
This suggests to me that you are copying the form from the supplied contactus.php page into another page. Is this not the case?
edgar294281
No, we used the same form that was downloaded from Webassist.
Also, the code that you provided included a fill for phone number which was not in the download from Webassist. The number fill is good to have but it is in the wrong place.
It is following the submit button.
Edgar
please post a copy of your contact page.
edgar294281
Jason,
I tried the form again but it still did not work.
I am attaching the content of the form so you can see what I have configured.
I'm sorry, the code I copied initially was from a contact form I had modified slightly, the phone number should not have been included.
I have modified the code in my previous reply to be the code from an unmodified contactus.php page.
I would like you to upload the attached file to your server to see if session management is working. Once uploaded, can you please provide a link.
edgar294281
Jason,
The form has been uploaded already.
This is a link to the form. I have not changed anything to code of the zipped file that I emailed back to you.
contactus.php
I have created a support ticket so we can look into this further. to view and edit your support incident, please log into your support history:
supporthistory.php?
