Modification of Registration Form
Thread begun 1/15/2010 10:14 pm by donegan | Last modified 1/25/2010 12:04 pm by Jason Byrnes | 4152 views | 8 replies |
donegan
Hi Everyone,
I need some help. I installed the Registration Solution Pack and made sure it worked.
Then I made some changes to the orginal Registration Form by adding three fields
Birth Month
Newsletter Format
Quilting Program
In addition I also deleted the following fields:
Phone Fax
Address
Address2
ZipCode
Next I uploaded the new page to my site:
users_Registration.php
Now the page does not work properly.
Not sure what I need to do to fix it.
Would appreciate some help in this matter.
shadow329043
I couldn't tell that there was a problem - what are you experiencing?
Shadow
In order to add new fields to the registration form, and have them stored in the database, you will need to perform a couple extra steps:
1) The new Columns need to be added to the users table in the MySQL Database.
2) You will need to use DataAssist to modify the insert record server behavior to bind the new form fields to the new Database columns.
donegan
The fields were added to the database.
I followed the instructions in the Data Assist to bind the fields.
I am not sure what else to do.
it looks like validation is failing.
Find the following code:
if ($WAFV_Errors != "")  {
    PostResult($WAFV_Redirect,$WAFV_Errors,"usersRegistration");
and change it to:
this will werite a coma separated list of the failed validations to the screen, please posst this back along with a copy of your page./
donegan
As outlined in my original message, you can see my form page by going to the following link:
The line of code you directed me to post in my form is exactly the same information
already on lines 74 and 75 in the code.
Sorry, the code to change it to is:
    die($WAFV_Errors);
I need for you to add a copy of the php page to a zip file and send the file with your reply so I can examine the php code.
donegan
Attached you will find my User_registration.php Page.
I do not see the code change I suggested on the page.
After changing the code, what is the outcome when you test this page?
