Sort for Dynamic Menu
Thread begun 1/15/2010 12:57 pm by jaa397769 | Last modified 1/15/2010 2:00 pm by jaa397769 | 1575 views | 2 replies |
jaa397769
How do I set my database to sort in the order that I want for my dynamic menu. Theres seems to be no logic to the order that its sorting in now. The field ID's are not decsending or Ascending, their actually doing both for example
ID 17 Mens Apparel
ID 16 Womens Apparel
ID 15 Youth Apparel
ID 14 Footwear
ID 18 Hunting Apparel
ID 19 Auto
ID 20 Home
ID 21 Camping
ID 22 Fishing
ID 23 Archery
ID 24 Hunting
How do I get it to sought in this order:
Hunting
Archery
Fishing
Camping
Home
Auto
Hunting Apparel
Mens Apparel
Womens Apparel
Youth Apparel
Footwear
Do I have to go into the php admin of MySQL and change the value for the field ID?
Thank you
siteontimeBeta Tester
Hi If you are referring to the menu at the top of the page you will need to change this code in the file CSSMenuWriter/cssmw_home/menu.php
mysql_select_db($database_localhost, $localhost);
$query_menuwriter_productcategories = "SELECT CategoryName, CategoryID FROM productcategories";
$menuwriter_productcategories = mysql_query($query_menuwriter_productcategories, $localhost) or die(mysql_error());
$row_menuwriter_productcategories = mysql_fetch_assoc($menuwriter_productcategories);
$totalRows_menuwriter_productcategories = mysql_num_rows($menuwriter_productcategories);
after FROM productcategories add :
ORDER BY CategoryID DESC
So the code should now read:
$query_menuwriter_productcategories = "SELECT CategoryName, CategoryID FROM productcategories ORDER BY CategoryID DESC";
Hope that helps.
jaa397769
Thank you
I know what you gave me will work and thank you for the response, but I was able to achieve the same effect by just sorting the table on my sql server it self. Is it wrong that I achieved it that way?
