User and Admin Logout?
Thread begun 1/15/2010 11:34 am by woodenboat | Last modified 4/20/2010 2:45 pm by Eric Mittman | 9995 views | 26 replies |
woodenboat
I recently purchased the Registration Solution Pack. After setting it up, everything seems to be working ok except I don't see any log out links on the user pages or admin pages? What am I missing?
I do see a the users_LogOut.php file. Do I just create links to that for logging out?
I don't see one for the Admin pages?
thanks.
You just need to link to this page in order to make use of it. If you create a link to the logout page any user that is logged in that clicks on the link will be logged out. If the user is not logged in then they will be sent to the login page.
If you want a user logout page for the admin area you can use the same page as you are for the users but you will need to modify some of the things at the top. Currently lines 1-6 look like this in the logout page:
<?php require_once( "WA_SecurityAssist/Helper_PHP.php" ); ?>
if (!WA_Auth_RulePasses("Logged in to users")){
WA_Auth_RestrictAccess("users_LogIn.php");
If you made a copy of this page and put it in the admin area you would need to change these lines to be like this instead:
<?php require_once( "../WA_SecurityAssist/Helper_PHP.php" ); ?>
if (!WA_Auth_RulePasses("Administrator")){
You would also need to make a link to this page in your admin area.
woodenboat
Thanks for your help!
Your welcome, let us know if you have any other questions or if you run into any issues.
woodenboat
Another issue
I need to add a couple of textarea's to users_Registration.php
I do have access to the Extension Library.
I've added two textarea's using dreamweaver.
I open users_Registration.php and go to the Server Behaviors panel, I double click on "Insert Record" and get this error:
While executing onLoad in WAAB_Insert_SB.htm, the following JavaScript error(s) occured:
In File "WAAB_Insert_SB": initializeUI is not defined
I can't even find that file?
So what did I do wrong?
woodenboat
Just found the answer here:
showthread.php?t=3977&highlight=winfilecache+appdata
woodenboat
Making an Admin LogOut page
I duplicated the users_LogOut.php and put it in the Admin directory. I changed the code as you discribed above and put a logout link on one of the admin pages. But when selecting the logout, I'm taken to the Admin LogIn and the "You are logged in. You may proceed..." text is still showing and I'm not logged out?
Here is code from my admin LogOut page:
For some reason it seems that you are not passing the access restriction rule in place on this page. You can just remove the restriction, it should not make a different.
remove this:
woodenboat
thanks, now logout works.
zanimul379168
I'm having the same issue with logging the Admin out. I've tried both fixes as described above, yet I get this error message after removing the require once stanza:
Fatal error: Call to undefined function: wa_auth_rulepasses() in /stop-them.org/members/Admin/logout.php on line 2
Other than this issue it's working well.
