Bullets showing in Firefox
Thread begun 1/15/2010 1:16 am by Daryl | Last modified 1/15/2010 10:50 am by Jason Byrnes | 2840 views | 6 replies |
DarylBeta Tester
I have created a CSS Menu however in Firefox I can see Bullets before each link. In IE it displays correctly without them.
Any ideas?
DarylBeta Tester
Here is a screenshot of what I am seeing in Firefox....
Impossible to say what the problem is without seeing the code.
Can you send a link so I can see the problem to troubleshoot the cause.
DarylBeta Tester
I have attached all of the files created by the CSS Menu Wizard in a zip file
I am not able to reproduce the problem with the files you have sent.
Please send a link to the page you are experiencing the problem on so I can investigate the issue. I suspect your page has conflicting CSS on it that is causing the menu to display the bullets.
DarylBeta Tester
index.php
In your page, you have the following style that is causing the problem:
ul {
margin-top: 0px;
margin-bottom: 0px;
margin-left: 25px;
list-style-image: url(blank_files/blank_bullet.gif);
color: #000000;/*themecolour4%0;*/
remove the list-style-image attribute.
