Pass image in Session Variable
Thread begun 1/14/2010 7:30 pm by swoodmwood396702 | Last modified 1/19/2010 5:14 pm by Eric Mittman | 6280 views | 9 replies |
swoodmwood396702
I'm not using CSS Form Builder, but didn't know where else to put this Thread.
I am having a problem with knowing how to accomplish the following:
I have a Dreamweaver Form. In the form there is a color grid (Radio group with radio buttons). When I select a color (i.e. radio button), I pass the color choice to the next page using a Session Variable and therefore can display the text of the choice (i.e. Black) for the customer to confirm.
<td width="21" bgcolor="#000000"><p class="style4">
<input type="radio" name="BallColor" value="Black" id="Black" />
</td>
<td width="21" bgcolor="#BF202E"><span class="style6">
This is working Great.
The issue is that I ALSO want to pass an image (that I have stored in my server directory) for the same choice (i.e. Black.jpg) but I can't figure it out, so don't know if it's possible. I have to think I could enter some custom code to make it work, but I'm not a programmer, so don't know what to do.
Here's an example of what I tried (remember, I'm not a programmer) and obviously, it didn't work:
<input type="radio" AND "image"src="../Colors/formimages/Black.jpg" name="BallColor" value="Black" id="Black" />
I know a little about working with my database and recordsets and stuff, so maybe you'll recommend a solution using these tools?...
Any help would be greatly appreciated. My hair is starting to fall out : (
You will not be able to pass the image to the next page this way. When you have an input in a form it is the value that will be posted. You will need some way to associate the image with the selection. Do your images all relate to the choice directly? In your example the value of the radio option was Black, and the image was Black.jpg. You could use the value of the radio selection to show the image on the next page with some code like this:
<img  src="../Colors/formimages/<?php echo $_POST['BallColor'?>.jpg"/>
This is using the posted reference for the variable, you would want to use your session variable that is holding this value in it's place. If all of your options and image names match up like this then this would be one way you can get the image for the selection made to show on the next page.
swoodmwood396702
would nominee
Thanks Eric, I'll try it.
I'm wanting to pass the Text value of the color AND an image for the color.
So, if I change the value of BallColor to "Black.jpg", then the user will see "Black.jpg" as the Text description.
Perhaps, I don't need the Text description, maybe I can just show the image of the color instead.
The key to being able to select one value and show more information about the selection is to associate the corresponding details with the selection that is made. This is something that is much more difficult on a static page where the information only comes from a form or hard coded values. Normally this type of thing would be done with dynamic info from a database.
For example, if you have a table that had records for each choice and that table had columns for the color, the image, and the description you could just set the value of the selection to the id for the record in the db. Then on the next page you would have a recordset that would look up the other corresponding values based on the id that you passed. Having a user make one selection and having multiple values come from this one selection can be tricky without using a database. You could do something similar to the recordset lookup and just have a case statement that depending on the value of the radio option selected other variables can be set to the corresponding values for the image and color.
swoodmwood396702
Actual image is not seen
The problem is that I haven't posted anything to my Database yet. I want the customer to confirm their choices, before committing their entries to the database.
So, I'm just spitting back their entries to them with a message to confirm them. Once they confirm, and move to the next step in the process, their choices are committed to the database.
I entered the line of code that you specified earlier:
<img src="../Colors/formimages/<?php echo $_POST['BallColor'] ?>.jpg"/>
The image is getting mapped correctly to the image in my server directory, but I don't see an actual picture. It's a box with a little x in it. I don't think that authorization or permissions is an issue.
I'm also wondering why we're not entering the echo $_SESSION command for this procedure? When I was passing the TEXT value for "BallColor", I would have the code as follows:
<?php echo $_SESSION['BallColor']; ?>
Shouldn't I have to echo the SESSION before telling the page to POST the answer?
Thanks!
You would use the session variable reference if this value is held in a session variable and is not posted. Without more knowledge of how the pages are set up it is difficult to say what value you should use. Do you have a link to the live page where this can be seen?
Also, when I was making reference to the db I was referring to the choices the user is selecting from, not the choices they are making. For example, if you had a table for the items in your db and you had records that contained the corresponding values you could just reference that record with a recordset and get back all of the info associated with that option.
Like I mentioned, it can be pretty tricky getting more than a single piece of info back from a form with only one value. If you can post back with the pages in question I might have a better idea of what the interaction is and a way for you to get the values you need.
swoodmwood396702
Screen shots
This post has been deleted.
swoodmwood396702
reposting screen shots
I attached some screen shots.
Thanks!
I was not able to view your attachment. Please post back with links to the two pages and include some info about how the pages are supposed to interact and what is not working now that you are trying to get in place. I think with some more info about the pages and the situation I will better be able to help you.
swoodmwood396702
Solved
My images were in the correct location (in my dreamweaver folder structure) but not on the actual Server (at Yahoo). Once I loaded the images to the Yahoo folder, I was able to see my image.
Thanks.
