How to vary widths of 'Level 0' menu tabs?
Thread begun 1/14/2010 7:10 pm by dev396590 | Last modified 1/18/2010 9:46 am by dev396590 | 3061 views | 4 replies |
dev396590
Dear Friends,
First time working with CSS MenuWriter 2, and having little luck fitting a basic top nav tab menu in a 940px div. I need to make one tab, say 125px, another 225px, and so on...
I found the following fix in the forum, but it doesn't work:
<li><span><a href="index.html" style="width:50px;">Home</a></span></li>
Not being a PHP master doesn't help either, as this is code code generated in 'menu.php':
<li><a href="<?php echo($assumedRoot); ?>index.php">Home</a></li>
Is there a work-around for this, or did I miss something in the setup wizard?
Any help would be most appreciated! Thanks in advance.
neilo
Hiya dev,
The 'style' part of the first example you gave is: style="width:50px;"
It should work fine if you place the inline style into the same relative format and position in the second example:
<li><a href="<?php echo($assumedRoot); ?>index.php" style="width:50px;>Home</a></li>
Inline styles supercede external stylesheets, so whatever styles you put in there should be effective.
The format is:
<someTag  ID=TheElementID  style="style-property:this_value;  style-property:this_value;" /> What ever content you are putting between the tags </ClosingTag>
This is quite a good place for finding stuff out
dev396590
Thank you!
Hey Neilo,
Thank you very much! That did the trick! Although the closing " is needed ;-):
... style="width:50px; ...
One thing however, now the submenus do not line up properly. They vary between 10px-15px to the left of the 'Level 0' nav tab... in other words, the top tab and dropdown are not flush left (in this case)...
Any thoughts on how to control the location of just the 'Level 1' tabs?
Thanks again for your help, very much appreciated!
neilo
Oops - yes, - am yet to post something without a typo.
In the menu.php again, you can specify that for individual elements by addiing an inline style to the ul class="level-1" element, using ' style="left:0px;" '
<ul class="level-1" style="left:0px;">
You can try different amounts, - minus numbers are also allowed: style="left:-10px;"
This property is set (or can be set) universally in the menu.css stylesheet:
ul#cssmw0 ul.level-1 {
left: 0px;
padding: 1px 0 0 0;
top: 100%;
So that you can set the property for the whole level-1 (level-2 etc) sub menu for all, and then specify inline styles for individual elements. So i suppose the right order would be to check that the ul.level-1bit in the menu.css stylesheet is set to 'left:0px' first, and then adjust the individual elements' inline styles second.
I thought that these could be set in the CSSMenuWriter GUI during the creating menu process - maybe they can - but I couldn't find it!
dev396590
Thank you! Thank you! Thank you!
Hey Neilo,
Apologies for my delay in replying — your solution worked perfectly! Thank you so much for taking the time and effort to help. You've got some good karma coming your way, my friend ;-)
Thanks again!
