Images pictures properties
Thread begun 5/06/2009 12:27 am by webride281130 | Last modified 9/22/2009 7:12 am by Ray Borduin | 4189 views | 4 replies |
webride281130
Hello, I can not see (in the properties of the image) the preview of the images in the tab provided.
I can not see the picture (even if the link is good) in the editor WYSWYG.
Thank you
If the image src is correct the image will show. View the source code to try to determine what is wrong with the image path in the src.
webride281130
Why i can not see the image in wyswyg editor, source is ok ?
Regards
webride281130
images in wyswyg editor, source is ok
Originally Said By: webride281130
Regards
what should we do?
View the src value of the image... it must be wrong or else the image would show.
Do you have a sample url? Someone here could probably take a look and tell you what is wrong with it.
