Notice: Undefined index: DOCUMENT_ROOT in admin/contents_detail.php on line 17
Thread begun 1/14/2010 4:22 am by Stan.Shaw269802 | Last modified 1/14/2010 2:43 pm by Stan.Shaw269802 | 15919 views | 3 replies |
Stan.Shaw269802
Just installed PowerCMS on a Windows server. Most functions seem to work. One error I am see is on the view details page, as specified in the title, the document_root is being referenced but has not been defined. Where does this need to be defined, and how, to make this work properly?
DOCUMENT_ROOT is a predefined PHP variable, it is part of the SERVER collection. more informatin can be found here:
reserved.variables.php
See this post for adding the Document Root variabel when not present in IIS:
boaz at babylon dot com
30-Aug-2004 02:13
You can add $_SERVER["DOCUMENT_ROOT"] to IIS by editing the Environment Variables of your Windows server (was tested on WinXP SP2).
Right click on My Computer >> Properties >> Advanced.
In the System variables click on 'New' and Type in the name field 'DOCUMENT_ROOT' and in the value field the path to your IIS document root folder.
Don't forget to restart your Windows (IIS restart won't load the new settings).
Stan.Shaw269802
Thank you Jason,
I could add this to environment variables at the server level, but as this server hosts many webservers, I have to question what the specification would be. Each webserver would have a different document root.
Any additional thoughts are appreciated.
Stan.Shaw269802
morningbiretta
I found the following code should be added to any php module under IIS that references DOCUMENT_ROOT. I installed it in the module giving the error and it seems to work:
// let's make sure the $_SERVER['DOCUMENT_ROOT'] variable is set
if(!isset($_SERVER['DOCUMENT_ROOT'])){ if(isset($_SERVER['SCRIPT_FILENAME'])){
$_SERVER['DOCUMENT_ROOT'] = str_replace( '\\', '/', substr($_SERVER['SCRIPT_FILENAME'], 0, 0-strlen($_SERVER['PHP_SELF'])));
if(!isset($_SERVER['DOCUMENT_ROOT'])){ if(isset($_SERVER['PATH_TRANSLATED'])){
$_SERVER['DOCUMENT_ROOT'] = str_replace( '\\', '/', substr(str_replace('\\\\', '\\', $_SERVER['PATH_TRANSLATED']), 0, 0-strlen($_SERVER['PHP_SELF'])));
// $_SERVER['DOCUMENT_ROOT'] is now set - you can use it as usual...
