Problem on server
Thread begun 1/14/2010 3:01 am by info360637 | Last modified 1/15/2010 12:28 am by info360637 | 3338 views | 5 replies |
info360637
Problem on server
Hi - have installed Power CMS and working fine on local machine - but when I upload to webserver I get:
Warning: mysql_pconnect() has been disabled for security reasons in /home/madhouse/public_html/clients/ascot/cms/Connections/localhost.php on line 9
Fatal error: in /home/madhouse/public_html/clients/ascot/cms/Connections/localhost.php on line 9
Now I cannot find anything in the documentation about this line? What should it be other than the default:
$localhost = mysql_pconnect($hostname_localhost, $username_localhost, $password_localhost) or trigger_error(mysql_error(),E_USER_ERROR);
Any ideas??
info360637
Anyone?
Are there any support peeps available?
thanks
Jim
neilo
Hi Jim
Try changing 'mysql_pconnect' to 'mysql_connect' in the localhost.php file, see if that does it.
info360637
Thanks..
.. Neilo - you're good! Could you give me a quick rundown on why that worked - just like to learn where I can :-)
Thanks muchly,
Jim
neilo
Actually I'm not good. I had the problem with a hosting provider and server admin considered pconnect - 'pesistant' connection - to be a security risk.
Did look good for a minute though, didn't I?
info360637
Ah well -
...helped me out anyhow so thnx!
