VBScript Name Redefined on confirm.asp
Thread begun 1/14/2010 2:55 am by m_jelly386415 | Last modified 1/14/2010 9:54 am by Jason Byrnes | 2077 views | 1 replies |
m_jelly386415
I tried to merge the confirm page into my own design and now it won't work. Can anyone highlight where I might have gone wrong?
I get a VBScript Name redefined error, line 79
Dim MM_editCmd
Online at index.asp
Thanks so much, would be lost without your assistance
In ASP you use the DIM command to create a new variable. Once a variable has been Dimensioned, you cannot Dimension the same variable again.
The variable is first dimensioned at line 45, you can delete the Dimension command at line 79, the variable has already been created.
