3 selects in data assist
Thread begun 1/14/2010 12:14 am by revario.1331129 | Last modified 1/20/2010 10:42 am by Jason Byrnes | 1884 views | 3 replies |
revario.1331129
hello , sorry for my english , its very bad
i have data assit wizard ans i want use 3 select for insert a data
exemple :
search_xtra1 = "toto1"
search_xtra2 = "toto2"
search_xtra3 = "toto3"
and i want the resultat insertion in table search = "toto1toto2toto3"
but the insertion in the table is only "toto3"
my code as data assist
// WA Application Builder Insert
if (isset($_POST["Insert"])) // Trigger
$WA_connection = $liremessage;
$WA_table = "search";
$WA_sessionName = "WADA_Insert_search";
$WA_redirectURL = "detail_lexique.php";
$WA_keepQueryString = false;
$WA_indexField = "search_id";
$WA_fieldNamesStr = "search_nom|search_nom_uk|search_desc|search_xtra|search_doc_initiation|search_doc|search_site_blog|search_livre|search_forum|search_pub_partenaire_01|search_auteur|search_date";
$WA_fieldValuesStr = "".((isset($_POST["search_nom"]))?$_POST["search_nom"]:"") ."" . "|" . "".((isset($_POST["search_nom_uk"]))?$_POST["search_nom_uk"]:"") ."" . "|" . "".((isset($_POST["search_desc"]))?$_POST["search_desc"]:"") ."" . "|" . "".((isset($_POST["search_xtra"]))?$_POST["search_xtra"]:"") ."" . "|" . "".((isset($_POST["search_doc_initiation"]))?$_POST["search_doc_initiation"]:"") ."" . "|" . "".((isset($_POST["search_doc"]))?$_POST["search_doc"]:"") ."" . "|" . "".((isset($_POST["search_site_blog"]))?$_POST["search_site_blog"]:"") ."" . "|" . "".((isset($_POST["search_livre"]))?$_POST["search_livre"]:"") ."" . "|" . "".((isset($_POST["search_forum"]))?$_POST["search_forum"]:"") ."" . "|" . "".((isset($_POST["search_pub_partenaire_01"]))?$_POST["search_pub_partenaire_01"]:"") ."" . "|" . "".((isset($_POST["search_auteur"]))?$_POST["search_auteur"]:"") ."" . "|" . "".((isset($_POST["search_date"]))?$_POST["search_date"]:"") ."";
$WA_columnTypesStr = "',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,NULL|'";
$WA_connectionDB = $database_liremessage;
mysql_query("SET NAMES UTF8");
$insertParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
$_SESSION[$WA_sessionName] = mysql_insert_id();
if ($WA_redirectURL != "") {
and i have this 3 select ( make with dreamweaver )
<th align="left" valign="top" bgcolor="#FFF0C4" class="WADADataTableHeader">1er lien vers le cours :</th>
<td bgcolor="#FFF0C4" class="WADADataTableCell"><select name="search_xtra" id="search_xtra">
do {
<option value="<?php echo $row_afficherubrique['ref_nom'] ;?><?php echo "#" ;?><?php echo $row_afficherubrique['ref_cours'] ;?> "><?php echo $row_afficherubrique['ref_nom']?></option>
} while ($row_afficherubrique = mysql_fetch_assoc($afficherubrique));
$rows = mysql_num_rows($afficherubrique);
if($rows > 0) {
mysql_data_seek($afficherubrique, 0);
$row_afficherubrique = mysql_fetch_assoc($afficherubrique);
</select></td>
</tr>
<tr>
<th align="left" valign="top" bgcolor="#FFF0C4" class="WADADataTableHeader">2 em lien vers le cours :</th>
<td bgcolor="#FFF0C4" class="WADADataTableCell"><select name="search_xtra2" id="search_xtra2">
do {
if($rows > 0) {
</select></td>
</tr>
<tr>
<th align="left" valign="top" bgcolor="#FFF0C4" class="WADADataTableHeader">3 em lien vers le cours :</th>
<td bgcolor="#FFF0C4" class="WADADataTableCell"><select name="search_xtra3" id="search_xtra3">
do {
if($rows > 0) {
</select></td>
thank you for help !
In the Insert record behavior, you can only bind a database column to one form element at a time, but you can overcome this by using copy and past.
First bind the search_xtra column to the search_xtra select list, this will add code similar to:
<?php echo(isset($_POST['search_xtra'])?$_POST['search_xtra']:"" ?>
copy the code that is created, then bind the search_xtra column to the search_xtra2 select list. This will create code similar to:
<?php echo(isset($_POST['search_xtra2'])?$_POST['search_xtra2']:"" ?>
place you cursor at the beginning of that code, then paste the code you copied previosly, so the code looks like:
<?php echo(isset($_POST['search_xtra'])?$_POST['search_xtra']:"" ?><?php echo(isset($_POST['search_xtra2'])?$_POST['search_xtra2']:"" ?>
copy that code, then bind the search_xtra column to the search_xtra2 select list. This will create code similar to:
<?php echo(isset($_POST['search_xtra3'])?$_POST['search_xtra3']:"" ?>
Place your cursor at the beginning off that code, and paste the code you copied previously so the full code looks like:
<?php echo(isset($_POST['search_xtra'])?$_POST['search_xtra']:"" ?><?php echo(isset($_POST['search_xtra2'])?$_POST['search_xtra2']:"" ?><?php echo(isset($_POST['search_xtra3'])?$_POST['search_xtra3']:"" ?>
You can then click OK to save your changes to the insert record behavior.
revario.1331129
thank you for help
I added this to the code
$WA_fieldValuesStr = "".((isset($_POST["search_nom"]))?$_POST["search_nom"]:"") ."" . "|" . "".((isset($_POST["search_nom_uk"]))?$_POST["search_nom_uk"]:"") ."" . "|" . "".((isset($_POST["search_desc"]))?$_POST["search_desc"]:"") ."" . "|" ?><?php echo((isset($_POST["search_xtra"]))?$_POST["search_xtra"]:"") ?><?php echo((isset($_POST["search_xtra2"]))?$_POST["search_xtra2"]:"") ?><?php echo((isset($_POST["search_xtra3"]))?$_POST["search_xtra3"]:"") ?><?php "|" . "".((isset($_POST["search_doc_initiation"]))?$_POST["search_doc_initiation"]:"") ."" . "|" . "".((isset($_POST["search_doc"]))?$_POST["search_doc"]:"") ."" . "|" . "".((isset($_POST["search_site_blog"]))?$_POST["search_site_blog"]:"") ."" . "|" . "".((isset($_POST["search_livre"]))?$_POST["search_livre"]:"") ."" . "|" . "".((isset($_POST["search_forum"]))?$_POST["search_forum"]:"") ."" . "|" . "".((isset($_POST["search_pub_partenaire_01"]))?$_POST["search_pub_partenaire_01"]:"") ."" . "|" . "".((isset($_POST["search_auteur"]))?$_POST["search_auteur"]:"") ."" . "|" . "".((isset($_POST["search_date"]))?$_POST["search_date"]:"") ."";
But only the first value is added in the table
How then I to make to insert 3 values of 3 select at the same time ?
Thank you for help
this prtion of the code:
"|" ?><?php echo((isset($_POST["search_xtra"]))?$_POST["search_xtra"]:""?><?php echo((isset($_POST["search_xtra2"]))?$_POST["search_xtra2"]:""?><?php echo((isset($_POST["search_xtra3"]))?$_POST["search_xtra3"]:""?><?php "|"
should be:
"|" .((isset($_POST["search_xtra"]))?$_POST["search_xtra"]:"") .", ".((isset($_POST["search_xtra2"]))?$_POST["search_xtra2"]:"") .", ".((isset($_POST["search_xtra3"]))?$_POST["search_xtra3"]:"") ."|"
