Express checkout not working
Thread begun 1/13/2010 3:09 pm by jaa397769 | Last modified 1/15/2010 3:07 pm by Jason Byrnes | 3421 views | 5 replies |
jaa397769
Here is the error message I received Please help.
Auth Request : <info removed>pp_cancel.phpAuthorization|
Auth Result : A7aXhax.4zxjuqT.HXHMWFXjWFUTAioSYPWmgcbNGFynNypwxmKF1cxK2010-01-13T23:01:12ZFailureb224849a8f1f4Security errorSecurity header is not valid10002Error2.201152253|
Get Request : |
Get Result : |
Process : |
Process Result : |
What is wrong?
See the following post:
showpost.php?p=32378&postcount=4
jaa397769
another question
I recreated the api key and it worked fine. Thank you.
My question now is I've created some items for my store in the database admin, how do I link them to my menu for viewing? Does this have to be a dynamic link?
When you add a product in the admin section, it will automatically be added to the navigation as long as you check the Available Online check box.
jaa397769
menu
Actually that was not the case at all, I had to create a dynamic menu link to get access to my database. That works. Now my question is how do I sort the categories? If I want a certain order do I have to go in the database and move the files around how I want them to stack?
Thank you
You can add on Order By Clause to your recordset to order them alphabetically by name. Other wise, you need to add the categories to the database in the order they should appear.
