Getting File Upload to work
Thread begun 1/13/2010 10:25 am by jay.malik396220 | Last modified 1/13/2010 4:46 pm by Jason Byrnes | 9397 views | 7 replies |
jay.malik396220
My action code is in a separate file, and I've tried to move code as best as I can guess.
The file upload is not working as a consequence. I will also have an issue adding the attachment to email as a second item.
Here's the form code:
if (!isset($_SESSION)) {
session_start();
<?php require_once( "../../WA_SecurityAssist/Helper_PHP.php" ); ?>
if (!WA_Auth_RulePasses("Customer Access")){
WA_Auth_RestrictAccess("accessdenied.php");
require_once("../../WA_DigitalFilePro/HelperPHP.php");
//WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
//WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "../uploads",
'FileName' => "[FileName]",
'DefaultFileName' => "",
'ResizeType' => "0",
'ResizeWidth' => "0",
'ResizeHeight' => "0",
'ResizeFillColor' => "" );
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End
<html xmln
<form enctype="multipart/form-data" action="processsupportrequest.php" method="post" name="form1" class="FormContent" id="form1">
<tr>
<td>Attachments:</td>
<td><span id="sprytextfield6">
<input name="upload" id="upload" type="file"/>
<span class="textfieldRequiredMsg">A value is required.</span></span></td>
</tr>
Here's the processing code:
session_start();
<head>
</head>
<body>
require_once('../../Connections/Centerline.php'); ?>
<?php require_once("../../WA_DigitalFilePro/HelperPHP.php"); ?>
<?php require_once("../../WA_Universal_Email/mail_PHP.php"); ?>
<?php require_once("../../WA_Universal_Email/MailFormatting_PHP.php"); ?>
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
include_once $_SERVER['DOCUMENT_ROOT'] . '/securimage/securimage.php';
$securimage = new Securimage();
if ($securimage->check($_POST['captcha_code']) == true) {
// capthca entered correctly
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
WA_DFP_UploadFiles("WA_UploadResult1", $_FILES["upload"], "3", "[ExistingFileName]_[Increment]", "false", $WA_UploadResult1_Params);
//WA Universal Email object="mail"
//Send Loop Once Per Entry
$RecipientEmail = "support@centerlinesft.com";include("../../WA_Universal_Email/WAUE_processsupportrequest_1.php");
//Send Mail All Entries
header("Location: ");
$insertGoTo = "thankyouemail.php";
if (isset($_SERVER['QUERY_STRING'])) {
$insertGoTo .= (strpos($insertGoTo, '?')) ? "&" : "?";
$insertGoTo .= $_SERVER['QUERY_STRING'];
header(sprintf("Location: %s", $insertGoTo));
else {
print '<p align="center" style="color: #DD0000; font-weight: bold;">Incorrect verification code</p>';
print '<p align="center"><a href="javascript:history.go(-1);">Go back and try again</a></p>';
</body>
</html>
And the email template:
$MailAttachments = "";
$MailBCC = "";
$MailCC = "";
$MailTo = "";
$MailBodyFormat = "";
$MailBody = "";
$MailImportance = "";
$MailFrom = "Centerline Support Page|WA|support@centerlinesft.com";
$MailSubject = "Support Request - " . $_POST["Name"];
$_SERVER["QUERY_STRING"] = "";
//Global Variables
$WA_MailObject = WAUE_Definition("mail.allabuzz-ci.com","25","support@centerlinesft.com","","","");
if ($RecipientEmail) {
$WA_MailObject = WAUE_AddRecipient($WA_MailObject,$RecipientEmail);
else {
//To Entries
//Attachment Entries
//BCC Entries
//CC Entries
//Body Format
$WA_MailObject = WAUE_BodyFormat($WA_MailObject,0);
//Set Importance
$WA_MailObject = WAUE_SetImportance($WA_MailObject,"3");
//Start Mail Body
$MailBody = $MailBody . "<html><head></head><body>\r\n";
$MailBody = $MailBody . "\r\n";
$MailBody = $MailBody . "<p>Name: ";
$MailBody = $MailBody . ((isset($_POST["Name"]))?$_POST["Name"]:"");
$MailBody = $MailBody . "</p>\r\n";
$MailBody = $MailBody . "<p>Email: ";
$MailBody = $MailBody . ((isset($_POST["Email"]))?$_POST["Email"]:"");
$MailBody = $MailBody . "<p>Comments: ";
$MailBody = $MailBody . ((isset($_POST["Comments"]))?$_POST["Comments"]:"");
$MailBody = $MailBody . "<p>Attachment: ";
$MailBody = $MailBody . ((isset($_FILES["upload"]))?$_FILES["upload"]:"");
$MailBody = $MailBody . "</body></body></html>";
//End Mail Body
$WA_MailObject = WAUE_SendMail($WA_MailObject,$MailAttachments,$MailBCC,$MailCC,$MailTo,$MailImportance,$MailFrom,$MailSubject,$MailBody);
$WA_MailObject = null;
1) Some of the Digital file Pro code was not copied from the from page to the processing page:
2) in the DFP Server behavior, you do not need to click the lightning bolt next to the File Filed, instead, you should select the name of the file field from the drop down list.
3) In the email, you should not refer to the file from the file collection, instead, expand the WA Digital File pro Uploaded Files group and select the Server File name.
instead of having the form post to another page, it is much simpler to have the form post to itself, and add the upload and email server behaviors to the same page, you dont have top copy from one page to another that way.
jay.malik396220
Post action
Thanks Jason,
The main reason I use a different page is because I have not figured out how to test the captcha code and show an error on the same page (pretty much the same as your contact form for WebAssist).
Form code for captcha code is:
<tr valign="baseline">
<td align="right" nowrap="nowrap" class="InputTables"><p><img src="/securimage/securimage_show.php?sid=<?php echo md5(time()) ?>" alt="captcha" align="left" id="siimage" style="padding-right: 5px; border: 0" /><br />
<!-- pass a session id to the query string of the script to prevent ie caching -->
</p>
<p><a tabindex="-1" style="border-style: none" href="#" title="Refresh Image" onclick="document.getElementById('siimage').src = '/securimage/securimage_show.php?sid=' + Math.random(); return false"></a></p></td>
<td> <input type="text" name="captcha_code" size="10" maxlength="6" /></td>
</tr>
Error check code is:
else {
I see no reason why this code cannot be on the same page as the form.
jay.malik396220
Simple Example
I created a new and simple form with all behaviors in the same page. No upload, and no attachment to the email (no errors raised either).
Form Code:
// WA_UploadResult1 Params Start
// WA_UploadResult1_1 Start
if(isset($_POST["send"])){
WA_DFP_UploadFiles("WA_UploadResult1", "upload", "0", "", "false", $WA_UploadResult1_Params);
if ((isset($_POST["send"]))) {
$RecipientEmail = "jay@pivotier.com";include("../../WA_Universal_Email/WAUE_upload_1.php");
<html xmlns="http://www.w3.org/1999/xhtml"><!-- InstanceBegin template="../../Templates/Centerline_Pages.dwt" codeOutsideHTMLIsLocked="false" -->
<head>
<link href="../Assets/CSS/centerline_09.css" rel="stylesheet" type="text/css" />
<!--[if lte IE 6]>
<style type="text/css" media="all">
@import url("../../CSSMenuWriter/cssmw/menu_ie.css");
</style><![endif]-->
<script type="text/javascript" src="../../CSSMenuWriter/cssmw0/menu.js"></script>
@import url("../../CSSMenuWriter/cssmw0/menu.css");
</style>
<!--[if lte IE 6]>
@import url("../../CSSMenuWriter/cssmw0/menu_ie.css");
<!--[if lte IE 6]>
@import url("../../CSSMenuWriter/cssmw1/menu_ie.css");
function MM_preloadImages() { //v3.0
var d=document; if(d.images){ if(!d.MM_p) d.MM_p=new Array();
var i,j=d.MM_p.length,a=MM_preloadImages.arguments; for(i=0; i<a.length; i++)
if (a[i].indexOf("#")!=0){ d.MM_p[j]=new Image; d.MM_p[j++].src=a[i];}}
</script>
<!-- InstanceBeginEditable name="doctitle" -->
<title>SSRS Reporting for Dynamics NAV</title>
<!-- InstanceEndEditable -->
<meta name="Keywords" content="Microsoft Dynamics NAV,SSRS,Reporting Services,Pivotier,Flowfields,Report Definition Language,RDL,SQL Server" />
</head>
<body>
<div id="content">
<div id="Header">
<div id="leftcolumnbubble"></div>
<div id="rightcolumnbubble"></div>
<div id="gutterbubble"></div>
<div id="headerbubble"></div>
<div id="logo">
<div id="cline"><img src="../Assets/Elements/CEN_Weblogo.png" alt="logo" width="274" height="64" hspace="10" vspace="5" border="0" usemap="#GoHome" onload="MM_preloadImages('Assets/Elements/CEN_Webbox_TopLeft_03.png','Assets/Elements/images/currency.png','Assets/Elements/images/jumpers.png','Assets/Elements/images/Modernize.png','Assets/Elements/images/SSRS.png','Assets/Elements/images/visualize.png')" />
<map name="GoHome" id="GoHome">
<area shape="rect" coords="5,5,270,59" href="Centerline_Home.php" alt="Go to home page" />
</map>
</div>
<div id="title"><br />
<p><!-- InstanceBeginEditable name="Page_Menu_Text" -->Page_Menu_Text<!-- InstanceEndEditable --></p>
<div id="TitleBubble"></div>
</div>
</div>
<div id="navigation">
<p><?php require_once("../../CSSMenuWriter/cssmw0/menu.php"); ?></p>
</div>
</div>
<div id="pagecontent">
<div class="leftcolumn"><b class="rtop"><b class="r1"></b> <b class="r2"></b> <b class="r3"></b> <b class="r4"></b></b>
<div id="leftcolumncontent"><!-- InstanceBeginEditable name="Left_Column" -->Left_Column<!-- InstanceEndEditable --></div>
<b class="rbottom"><b class="r4"></b> <b class="r3"></b> <b class="r2"></b> <b class="r1"></b></b>
</div>
<div class="rightcolumn"><b class="rtop"><b class="r1"></b> <b class="r2"></b> <b class="r3"></b> <b class="r4"></b></b>
<div id="rightcolumncontent"><!-- InstanceBeginEditable name="Right_Column" -->
<form action="" method="post" enctype="multipart/form-data" name="form1" id="form1">
<p>&nbsp;</p>
<p>
<label>Name
<input type="text" name="name" id="name" />
</label>
</p>
<p>
<label>Email
<input type="text" name="email" id="email" />
</label>
</p>
<p>
<label>Select a File
<input type="file" name="upload" id="upload" />
</label>
</p>
<p>
<label>
<input type="submit" name="send" id="send" value="Send" />
</label>
</p>
</form>
</div>
</div>
<div id="footer">
<a href="contactus.php">Contact</a> | <a href="terms.php">Terms of Use</a> | <a href="privacy.php">Privacy</a> | <a href="Login.php">Login</a> | <a href="logout.php">Logout</a> | <a href="Centerline_Home.php">Home</a><br />
<br />
Copyright &copy; 2009-2010 Centerline Software, Inc. </div>
</div>
</body>
<!-- InstanceEnd --></html>
Email code:
$MailBCC = "";
$MailCC = "";
$MailTo = "";
$MailBody = "";
$MailFrom = "".$_SESSION['FirstName'] ."|WA|".$_SESSION['Email'] ."";
$MailSubject = "Support Email";
//Global Variables
$WA_MailObject = WAUE_Definition("mail.allabuzz-ci.com","25","","","","");
else {
//To Entries
//$WA_MailObject = WAUE_AddAttachment($WA_MailObject,"".((isset($_COOKIE[""]))?$_COOKIE[""]:"") ."");
$WA_MailObject = WAUE_AddAttachment($WA_MailObject,"".(realpath("../".$WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"])) ." ");
//BCC Entries
//CC Entries
//Body Format
//Set Importance
//Start Mail Body
$MailBody = $MailBody . ((isset($_POST["name"]))?$_POST["name"]:"");
$MailBody = $MailBody . ((isset($_POST["email"]))?$_POST["email"]:"");
//End Mail Body
to trouble shoot, add the following at line 1:
error_reporting
(E_ALL);
Then open the Bindings panel, expand the WA Uploaded Files Global Status and add the debug info binding to the page.
Post back the debug info after trying to upload a file.
jay.malik396220
Post Back?
Sorry to be dense, but how do I post back the debug info.
I have inserted Debug Info on the form.
Right now when submitted it finishes and then presents a page refresh error . Going back does not show the debug info.
What I meant was to copy the debug info from your page into your response.
if you are getting an error, you will need to provide the full error text for me to have an idea of the cause. If you could also include a zip file with the php page, that would help tracking down the error as well.
