Error? Ecart Store Summary...
Thread begun 1/13/2010 7:53 am by Art | Last modified 1/14/2010 10:25 am by Jimmy Wu | 3193 views | 6 replies |
Art
Command(WA_editCmd) #prior version#
I've upgraded a few times to the newest versions and currently have eCart ver. 4. 5.2
Now, when I'm looking at the behaviors window in the checkout, I'm seeing the above line just under "eCart Store Summary in Database"
When I recreate the store summary..., the same message appears.
What is this? Should I ignore it? What can I do to eliminate it?
Jimmy Wu
What is the error that you are getting when you run the page?
Also could you post up some of the code around that so that I can see some context?
Art
<%' WA eCart Store Cart Summary in Db
if ((Request.ServerVariables("Request_Method") = "POST") AND (inStr(Unescape(cStr(Request.ServerVariables("HTTP_REFERER"))),Unescape(Request.ServerVariables("SERVER_NAME")&Request.ServerVariables("SCRIPT_NAME"))) > 0)) then
WA_connection = MM_connShnta_STRING
WA_table = "dbo.atblCCN"
WA_redirectURL = ""
WA_indexField = "InvoiceID"
WA_fieldNamesStr = "Type|CCN|CSC|Amount|aYear|aMonth|CustID|CreditOrCall|CallBackPhone"
WA_fieldValuesStr = "" & cStr(cStr(Request.Form("CCType"))) & "" & "|" & "" & cStr(cStr(Request.Form("CCNumber"))) & "" & "|" & "" & cStr(cStr(Request.Form("CSC"))) & "" & "|" & WA_eCDB_ConvertNumber("" & cStr(WA_eCart_GrandTotal(shnta_eCart)) & "") & "|" & "" & cStr(cStr(Request.Form("CCYear"))) & "" & "|" & "" & cStr(cStr(Request.Form("CCMonth"))) & "" & "|" & WA_eCDB_ConvertNumber("" & cStr( Session("ssSessionID") ) & "") & "|" & WA_eCDB_ConvertNumber("" & cStr(cStr(Request.Form("payType"))) & "") & "|" & "" & cStr(cStr(Request.Form("CallBackNumber"))) & ""
WA_columnTypesStr = "',none,''|',none,''|',none,''|none,none,NULL|',none,''|',none,''|none,none,NULL|none,none,NULL|',none,''"
WA_sessionName = "ssStoreInvoice"
indexFieldIndex = -1
WA_fieldValues = Split(WA_fieldValuesStr,"|")
WA_fieldNames = Split(WA_fieldNamesStr,"|")
WA_columns = Split(WA_columnTypesStr,"|")
set WA_editCmd = Server.CreateObject("ADODB.Command")
updateFieldValue = ""
WA_editCmd.ActiveConnection = WA_connection
if (WA_redirectURL <> "" AND Request.QueryString <> "" AND Request.QueryString.Count > 0) then
if (inStr(WA_redirectURL,"?") > 0) then
WA_redirectURL = WA_redirectURL & "&"
else
WA_redirectURL = WA_redirectURL & "?"
end if
WA_redirectURL = WA_redirectURL & Request.QueryString
end if
for i = 0 to Ubound(WA_fieldNames)
if (WA_indexField = WA_fieldNames(i)) then
indexFieldIndex = i
exit for
end if
next
if (indexFieldIndex >= 0) then updateFieldValue = WA_fieldValues(indexFieldIndex)
if (updateFieldValue = "") then updateFieldValue = cStr(Session(WA_sessionName))
updateColType = "none,none,NULL"
updateColType = WA_columns(indexFieldIndex)
end if
if (updateFieldValue <> "" AND updateFieldValue <> "undefined") then
valueForWhere = WA_generateInsertParams(Array(WA_indexField), Array(updateColType), Array(updateFieldValue), -1)
sqlstr = "select " & WA_indexField & " from " & WA_table & " where " & WA_indexField & " = " & valueForWhere(2) & " order by " & WA_indexField & " DESC"
set WA_eCartRecordset = Server.CreateObject("ADODB.Recordset")
WA_eCartRecordset.ActiveConnection = WA_connection
WA_eCartRecordset.Source = sqlstr
WA_eCartRecordset.CursorType = 0
WA_eCartRecordset.CursorLocation = 2
WA_eCartRecordset.LockType = 1
WA_eCartRecordset.Open()
if (NOT WA_eCartRecordset.EOF) then
updateFieldValue = cStr(WA_eCartRecordset.Fields.Item(WA_indexField).Value)
else
end if
WA_eCartRecordset.Close()
end if
updateParamsObj = WA_generateInsertParams(WA_fieldNames, WA_columns, WA_fieldValues, indexFieldIndex)
WA_editCmd.CommandText = "update " & WA_table & " SET " & updateParamsObj(3) & " where " & WA_indexField & " = " & valueForWhere(2)
WA_editCmd.Execute()
WA_editCmd.ActiveConnection.Close()
else
insertParamsObj = WA_generateInsertParams(WA_fieldNames, WA_columns, WA_fieldValues, -1)
WA_editCmd.CommandText = "insert into " & WA_table & " (" & insertParamsObj(1) & ") values (" & insertParamsObj(2) & ")"
end if
if (indexFieldIndex < 0) then
obj = WA_generateWhereClause(WA_fieldNames, WA_columns, WA_fieldValues, indexFieldIndex)
sqlstr = "select " & WA_indexField & " from " & WA_table & " where " & obj & " order by " & WA_indexField & " DESC"
if (NOT WA_eCartRecordset.EOF) then Session(WA_sessionName) = WA_eCartRecordset.Fields.Item(WA_indexField).Value
else
Session(WA_sessionName) = updateFieldValue
end if
else
Session(WA_sessionName) = WA_fieldValues(indexFieldIndex)
end if
if (WA_redirectURL <> "") then
Response.Redirect(WA_redirectURL)
end if
end if
Art
BTW, I have not posted this to see how it works on the site. I'll try this to see what happens.
Art
OK, I've tried the page and it doesn't show an error.
It also doesn't go anywhere when I click submit order
I then went back to the page in Dreamweaver and when I double clicked on the "prior version" behavior, a message pops up and saying "This server behavior was created with a prior version of UltraDev. It will be replaced with the current version when you click OK in the server behavior dialog box."
I then click OK and the "Command" box remains. The WA_editCmd command box has three SQL lines: "UPDATE, SET, WHERE" and everything else in that window is blank.
When I close that, the eCart Store Summary in Database behavior disappears along with the "prior version" line. All the code goes away too.
I then opened up the original again and double clicked on the eCart Object behavior just to make sure it was using the correct eCart and then double clicked on the "Store
Summary" behavior again, saved and uploaded. ...Same thing...it didn't go anywhere.
Art
Well, it seems to have gone away.
After I did all this, I then reboot Dreamweaver because I was getting some "saved outside Dreamweaver" warnings and when I came back into DW, the error in the Behavior window was gone and when I tested it, it worked!
I think I'm in good shape now but I don't really know what happened. I guess, metaphorically speaking, all the stars had to be aligned correctly.
I guess, for now, this is settled.
Thanks for your attention.
Jimmy Wu
Great to hear you were able to get this issues resolved. If you run into any additional issues, feel free to open a new thread.
