How to view SQL return code
Thread begun 1/13/2010 6:07 am by david.barrack304604 | Last modified 1/13/2010 10:08 am by Jason Byrnes | 1447 views | 1 replies |
david.barrack304604
What is the easiest way to view the SQL return code when using DataAssist? I have an update that is not working and have no real way to debug this to resolution. I check the variables beforehand which looks fine but can't evaluate what MySQL is doing.
In the update cose, look for the following line:
$MM_editCmd = mysql_query($WA_Sql, $WA_connection) or die(mysql_error());
edit it to:
die($WA_Sql);
this will write the sql to the screen and stop processing to help debug the issue.
