Form returns blank page
Thread begun 1/12/2010 3:04 pm by sandy259886 | Last modified 1/13/2010 9:26 am by Jason Byrnes | 2873 views | 3 replies |
sandy259886
I am trying to get the Pear Mail option work. I have tried everything. I have a path to "pear" per the location on server. I have set the form to post and send email upon "submit" with a confirmation page showing up next. I press the "submit" button and the screen goes blank, but the url stays on the form page.
I am using version 3.0.7 on a Windows Vista machine.. (I hate Vista).
When a page displays blank, it means a php error has occurred, add the following to line 1 of the form page to turn error reporting on for troubleshooting:
error_reporting
(E_ALL);
sandy259886
message below
Warning: require_once(/usr/sbin/sendmailMail.php) [function.require-once]: failed to open stream: No such file or directory in /home/sandyrumsey/public_html/WA_Universal_Email/PEAR_Mail_using_SMTP_PHP.php on line 115
Fatal error: require_once() [function.require]: Failed opening required '/usr/sbin/sendmailMail.php' (include_path='.:/usr/share/pear:/usr/share/php') in /home/sandyrumsey/public_html/WA_Universal_Email/PEAR_Mail_using_SMTP_PHP.php on line 115
Hmmm... the path to the smtp mail is supposed to be /usr/sbin/sendmail --- Why did this appeal "Mail.php?" to the path? Is that the problem?
Part of the Pear package is a Mail.php file. Universal Email needs to load this file. It is located in the Pear Path. When you enter the Path to Pear, you must include a trailing slash. the path should be entered as:
/usr/sbin/sendmail/
Universal Email will automatically append Mail.php to the end of the path you enter:
/usr/sbin/sendmail/Mail.php
If you dont enter the trailing slash, the path becomes:
which causses the error.
