Warning and Fatal Error message
Thread begun 1/12/2010 9:54 am by mrobben375515 | Last modified 1/12/2010 10:32 am by Jimmy Wu | 1479 views | 1 replies |
mrobben375515
I'm working on a test site and changed the menu using CSS Menu Writer. When I uploaded the changes I started getting the following error message...
Warning: require_once(CSSMenuWriter/cssmw/menu.php) [function.require-once]: failed to open stream: No such file or directory in /home/content/o/n/e/onetoonemktg/html/contactus.php on line 184
Fatal error: require_once() [function.require]: Failed opening required 'CSSMenuWriter/cssmw/menu.php' (include_path='.:/usr/local/php5/lib/php') in /home/content/o/n/e/onetoonemktg/html/contactus.php on line 184
the address is 1to1marketing-llc.com...the site opens fine but when you click on the "winners", "tell your friends", or "contact us" links the message comes up. Please help
Jimmy Wu
Make sure you upload your CSSMenuWriter directory and all its contents in to your server. It appears that this directory is not there, so that is what is causing the errors.
