Repeat selection filtered by another recordset
Thread begun 1/12/2010 8:44 am by Les Crowley | Last modified 1/12/2010 5:58 pm by Jimmy Wu | 2222 views | 3 replies |
Les CrowleyBeta Tester
I'm doing a multiple insert and using repeat selection.
I'm filtering the repeat selection with another recordset via do while, to prevent duplicate from being entered into the database.
The multiple insert works without the filtering and insets the records into the database.
With the filtering it displays the filtered records (placing gaps where the removed -filtered out - records would be) but it will only insert sequential records into the database - if I try to insert the first and forth items - it only inserts the first - if I try to insert record 1,2 and 3 it inserts 1,2 and 3 - if I try to insert 1,2 and 5 it will only insert 1 and 2 and not 5. Hope I'm being clear on this... I'm looking to get all records inserted and remove the gaps where the other recordset has filtered out records.
Any help on this is appreciated. The code is below...
// RepeatSelectionCounter_1 Begin Loop
$RepeatSelectionCounter_1_IterationsRemaining = $RepeatSelectionCounter_1_Iterations;
while($RepeatSelectionCounter_1_IterationsRemaining--){
if($RepeatSelectionCounterBasedLooping_1 || $row_artcategories){
$tempartcat = 0000;
do {
if ($row_artcategories['categoryname'] == $row_artcatsselected['category']) {
$tempartcat = 9999 ;
} while ($row_artcatsselected = mysql_fetch_assoc($artcatsselected));
mysql_data_seek($artcatsselected, 0);
if ($tempartcat != 9999) {
<tr>
<td align="left" valign="top">&nbsp;</td>
<td align="left" valign="top"><input type="hidden" name="retailerid_mihidden_<?php echo $RepeatSelectionCounter_1; ?>" id="retailerid_mihidden_<?php echo $RepeatSelectionCounter_1; ?>" value="1" />
<input type="checkbox" name="catselect_<?php echo $RepeatSelectionCounter_1; ?>" id="catselect_<?php echo $RepeatSelectionCounter_1; ?>">
<input name="categoryid_<?php echo $RepeatSelectionCounter_1; ?>" type="hidden" id="categoryid_<?php echo $RepeatSelectionCounter_1; ?>" value="<?php echo $row_artcategories['categoryid']; ?>">
<input name="categoryparent_<?php echo $RepeatSelectionCounter_1; ?>" type="hidden" id="categoryparent_<?php echo $RepeatSelectionCounter_1; ?>" value="<?php echo $row_artcategories['categoryid']; ?>">
<input name="retailerid_<?php echo $RepeatSelectionCounter_1; ?>" type="hidden" id="retailerid_<?php echo $RepeatSelectionCounter_1; ?>" value="<?php echo $_SESSION['CustomerID']; ?>">
<?php echo $row_artcategories['categoryname']; ?>
<input name="ItemID_<?php echo $RepeatSelectionCounter_1; ?>" type="hidden" id="ItemID_<?php echo $RepeatSelectionCounter_1; ?>" value="<?PHP echo $_GET['ItemID'];?>">
<input name="category_<?php echo $RepeatSelectionCounter_1; ?>" type="hidden" id="category_<?php echo $RepeatSelectionCounter_1; ?>" value="<?php echo $row_artcategories['categoryname']; ?>"></td>
</tr>
} // RepeatSelectionCounter_1 Begin Alternate Content
else{
<tr>
<td>&nbsp;</td>
<td>&nbsp;</td>
</tr>
<?php } // RepeatSelectionCounter_1 End Alternate Content
if(!$RepeatSelectionCounterBasedLooping_1 && $RepeatSelectionCounter_1_IterationsRemaining != 0){
if(!$row_artcategories && $RepeatSelectionCounter_1_Iterations == -1){$RepeatSelectionCounter_1_IterationsRemaining = 0;}
$row_artcategories = mysql_fetch_assoc($artcategories);
$RepeatSelectionCounter_1++;
} // RepeatSelectionCounter_1 End Loop
Jimmy Wu
It looks like a similar issue has come up with using checkboxes and if a checkbox is skipped, the rest of the items do not get inserted. It looks like the workaround to this issue was to put in a hidden form field into repeat region and use that hidden form field for loopedFields. This will loop through all the items and then when inserting, it will only insert when the checkbox is checked.
Would something like that work for you?
Thanks Jimmy. That worked like a charm... hopefully this will be fixed in future dot release of DataAssist.
Jimmy Wu
Glad it worked out for you. If you run into any additional issues, feel free to open a new thread.
