Sending Email on an Update Form Page
Thread begun 1/12/2010 7:21 am by karen.marley367377 | Last modified 1/14/2010 11:53 am by Jason Byrnes | 3572 views | 7 replies |
karen.marley367377
Hi
I have an update form. The page includes two email server behaviours. I have left the redirect after update blank and set the first email server behaviour to redirect after button is pressed. The form updates okay but the email is not sent.
I have an email server behaviour on one of the details pages so I know the settings are correct.
<?php require_once("WA_Universal_Email/mail_PHP.php"); ?>
<?php require_once("WA_Universal_Email/MailFormatting_PHP.php"); ?>
// WA Application Builder Update
if (isset($_POST["submit"])) // Trigger
$WA_connection = $DBNAME;
$WA_table = "properties";
$WA_redirectURL = "";
$WA_keepQueryString = false;
$WA_indexField = "MainPropertiesID";
$WA_fieldNamesStr = "Status";
$WA_fieldValuesStr = "".((isset($_POST["status"]))?$_POST["status"]:"") ."";
$WA_columnTypesStr = "',none,''";
$WA_comparisonStr = "=";
$WA_where_fieldValuesStr = "".((isset($_POST["WADAUpdateRecordID"]))?$_POST["WADAUpdateRecordID"]:"") ."";
$WA_where_columnTypesStr = "none,none,NULL";
$WA_where_comparisonStr = "=";
$WA_where_fieldNames = explode("|", $WA_indexField);
$WA_where_fieldValues = explode("|", $WA_where_fieldValuesStr);
$WA_where_columns = explode("|", $WA_where_columnTypesStr);
$WA_where_comparisons = explode("|", $WA_where_comparisonStr);
$WA_connectionDB = $database_DBNAME;
$updateParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WhereObj = WA_AB_generateWhereClause($WA_where_fieldNames, $WA_where_columns, $WA_where_fieldValues, $WA_where_comparisons );
$WA_Sql = "UPDATE `" . $WA_table . "` SET " . $updateParamsObj->WA_setValues . " WHERE " . $WhereObj->sqlWhereClause . "";
if ($WA_redirectURL != "") {
if ((isset($_POST["test_x"]))) {
//WA Universal Email object="mail"
//Send Loop Once Per Entry
$RecipientEmail = "".$row_rsmembers['EmailAddress'] ."";include("WA_Universal_Email/WAUE_Admin_properties_Update_1.php");
//Send Mail All Entries
if ("properties_Results.php"!="") {
header("Location: properties_Results.php");
if ((isset($_POST["reset"]))) {
$RecipientEmail = "".$row_rsmembers['EmailAddress'] ."";include("WA_Universal_Email/WAUE_Admin_properties_Update_3.php");
if (""!="") {
header("Location: ");
Your help is appreciated
Double check the triggers.
The update is set to trigger when the button Submit is pressed:
the first universal email behavior is set to trigger when the button test is pressed:
the second is set to trigger when the button reset is pressed:
try setting the UE behaviors to use the same trigger as the update behavior, button submit pressed.
karen.marley367377
double check the triggers - email from update form
Hi Jason, Have tried changing the trigger on the UE to be the same as the update form, but this still does not work (code below)
if ((isset($_POST["submit"]))) {
$RecipientEmail = "recipient@recipient.com";include("WA_Universal_Email/WAUE_Admin_properties_Update_1.php");
Does the update occur?
Does the page redirect to the properties_Results.php page?
It would help if you sent the entire page instead of pasting the code so I could see the entire code in context.
in the code you send, you have the to address as recipient@recipient.com
Is this what is entered on the live page? this is not a valid email address.
karen.marley367377
sending emails on an update form
Hi Jason,
I am reluctant to attach the page for security reasons. Are we still able to submit support tickets?
The file is not 100% necessary, we can continue on in this forum, but you have not addressed the other questions I asked:
Is recipient@recipient.com what is entered on the live page for the to address?
karen.marley367377
email on update form
the form updates correctly.
The redirect on the email server beviour redirects correctly as set.
I changed the email address for security.
If the redirect is being performed, it is trying to send the email, but the SMTP server is not relaying it for some reason. check with your host to see if they can look into the smtp server error logs to determine why the email is not being relayed by the smtp server.
