universal email and php
Thread begun 1/12/2010 6:27 am by chrishales96195 | Last modified 1/13/2010 9:35 am by Jason Byrnes | 2572 views | 3 replies |
chrishales96195
i have used univ email for years in asp environment now I have a unix server and am having troubles receiving the email.
They run cpanel and I clicked on the paer icon this is what I got:
Location of Your PHP Extension(s) and Application(s)
Path: /home/chrishal/php
So here is my script can you tell me what I am doing wrong
1) double check the trigger you are using. You have selected Currant page submit, but there is no form on this page. It looks another page submits to this page, you will need to use either the any form post or before page loads triggers.
2) Are you sure "localhost" is the correct way to refer to the smtp server? double check with the host for the correct smtp server name.
3) usually Pear Mail for SMTP is used when the SMTP server requires authentication, but you have not added a user name and password.
chrishales96195
now I get:
Parse error: syntax error, unexpected T_ENCAPSED_AND_WHITESPACE, expecting T_STRING or T_VARIABLE or T_NUM_STRING in /home/chrishal/public_html/bayplotter.com/WA_Universal_Email/WAUE_thanksreqproducts_1.php on line 9
You have a bad value for the from address in the WAUE_thanksreqproducts_1.php file. Change line 9:
$MailFrom        = "<?php $email = $_REQUEST['email'] ;?> ";
$MailFrom        = "".((isset($_POST["email"]))?$_POST["email"]:"")  ."";
