PowerStore2 & PowerGallery Integration
Thread begun 1/11/2010 11:34 am by Earth Tribe Studio | Last modified 2/11/2010 4:16 pm by Jimmy Wu | 2754 views | 4 replies |
Earth Tribe Studio
I have a store set up with PowerStore2 and I would like to integrate PowerGallery with it. Should I set up a new database for the PowerGallery? Is there anything else I should do? Will there be 2 separate admin areas, one for the store & one for the gallery?
Jimmy Wu
Yes, I would suggest installing the PowerGallery using a different database. Also you would have 2 different admin areas, so I would recommend installing the PowerGallery in a different directory if you want to upload it to the same server.
e394610
PowerStore 2 & PowerGalley
Are there any specific directions on this site (or anywhere) to make these two websassist extensions work together. I have tested the PowerStore 2 and had no issue testing and getting this to work.
I want to purchase PowerGallery but want to be sure there are some instructions somewhere before I do so I can make these 2 work together.
Any help please let me know.
Thanks,
Ernie
e394610
nevermind, I purchased and found the answer
for those, if any, ever wondering the same thing there is a source code to link to power store with in the admin part of the power gallery.
Jimmy Wu
As you noted, its pretty simple to get the PowerGallery to display within the PowerStore setting. Was there anything else you needed clarification on?
