Creating An Index Page?
Thread begun 1/11/2010 10:36 am by www.BigMusicGeek.com | Last modified 1/14/2010 4:53 pm by Eric Mittman | 2611 views | 3 replies |
I have used Power Gallery to create a number of Photo Galleries for my website and am very happy with the results. However, I am now wondering if there is an easy way to create an index page (featuring thumbnails) that will allow my users to select from all of the available options via a single page.
Any suggestions?
Thanks!
There is not a supported feature of the Power Gallery that will create a page like this for you, it would need to be created manually.
The idea is that you can query the db with a recordset like this:
SELECT *
FROM pg1_gallery
ORDER BY id ASC
This recordset will contain all of the galleries that you have. You would then need to a link for each way a gallery can be viewed, there will be 12 links total. You will have the six types of gallery and the light and dark for each of those. These links will go to a page that you have a PowerGallery code block on that might look like this:
 $pg_id
$_GET['pg_id'];
$pg_theme $_GET['theme'];
 include(
'C:/Websites/PowerGallery/galleries/' $_GET['type'] . '/index.php');
You will need to add parameters to each of the twelve links to pass along these values for the id, theme, and type. This is kind of a high level overview, how the links look in the end will depend on your page names and locations. Once the links are all crafted you would apply a repeat region around them so that you have a set of links for each gallery you have.
Please post back with any additional questions that you have about any part of this.
mds119803
Eric,
The Power Gallery is fantastic but I also have found that an index page with thumbnails and links to the galleries would be really helpful. Do you think that you might consider adding this as a 'bolt on optional feature' ? - I would certainly pay for it.
I have logged this as a feature request for Power Gallery so that the team responsible can take a look and make a decision in regards to this.
