Validating Multipage form
Thread begun 1/11/2010 8:55 am by Walikan | Last modified 1/25/2010 3:26 pm by Jimmy Wu | 6893 views | 11 replies |
Walikan
Hey Support,
I created three forms(page1.php, page2.php and page3.php) and can (custom coded) pass form field information using session variables from one page to another and eventually to the db. I have tried the server side validation and tested the form and it does not work. Is it pdssible to use VT to validate multipage form? Can some one help?
Appreciate your help in advance
Jimmy Wu
Are you applying validation to each page or attempting to validate all the information on the last page?
If you are applying server validation make sure to apply it to the page that the form action is set to, not on the same page that the form is on.
Walikan
Hello Jimmy,
Thanks for your prompt feedback. I have attached the Zip of the three pages
I am applying validation on each page. I do not know how to apply on all information on the last page.
Is is possible to do that? I must be doing something wrong
Each time I try to apply server validations, only the page that contain the form fields pops up, for instance, if I were to apply validation on page1.php, only the form fileds of page1.php pops up on the server validation window. But the action of page1 is set to page2.php. I must have not understood exactly what you meant. From the attachment you will probably see exactly where I am wrong.
Jimmy Wu
In Dreamweaver you will have to add the form data to the page you are applying the validation on. So on page2 you will go into the bindings panel and click on the "+" button. Then you will select form data and select page1 as the page to add the form data from. Then on page2 you will be able to validate on that form data and set the failed redirect to page1.
Walikan
Hello Jimmy,
Thanks a million. It worked perfectly. You made my day.
Just a very last question. I forgot to add a page (page.php) in the attachment on the previous post.
On the page.php, I have hand coded a php switch condition statement and I have a form below to integrate the switch statement. In the form there are 3 radio buttons representing Pages i e
radio button1 = page1.php
radio button2= page2.php
radio button3 =page3.php
When a user select say, radio button1 and complete the rest of the form fields and then clicks on the submit button, the user is redirected to page1.php
Similarly selecting radio button2 and complete the other form elements in the form and then clicks on submit button, the user is redirect to page2.php. I know I need to add a custom code on the form action, any help on how to achive this? See attachment for details
session start()
switch(#{destination}) {
case "1" :
header("Location: page1.php");
break;
case "2 ":
header("Location: page2.php");
break;
case "3 ":
header("Location: page3.php");
break;
exit();
<form id="form1" method="post" action=" ">
<table width="403" border="0">
<tr>
<td width="104"><p>
<label>
<input type="radio" name="select" value="p1" id="select_0" />
Page 1</label>
<br />
<label>
<input type="radio" name="select" value="p2" id="select_1" />
Page 2</label>
<br />
<label>
<input type="radio" name="select" value="p3" id="select_2" />
Page3</label>
<br />
</p></td>
<td width="144">&nbsp;</td>
<td width="141"><?php
if (ValidatedField('page1_214','page1_214')) {
if ((strpos((",".ValidatedField("page1_214","page1_214").","), "," . "1" . ",") !== false || "1" == "")) {
if (!(false)) {
<font color="#FF0000">Select one</font>
<?php //WAFV_Conditional page1.php page1_214(1:)
}?></td>
</tr>
<tr>
<td>Arrival Date</td>
<td><label>
<input name="ArrivalDate" type="text" id="ArrivalDate" size="10" />
</label></td>
<td><?php
if ((strpos((",".ValidatedField("page1_214","page1_214").","), "," . "2" . ",") !== false || "2" == "")) {
if (!(false)) {
<font color="#FF0000">Pick Date</font>
<?php //WAFV_Conditional page1.php page1_214(2:)
}?></td>
</tr>
<tr>
<td>Arrival Time</td>
<td><label>
<input type="text" name="ArrivalTime" id="ArrivalTime" />
</label></td>
<td><?php
if ((strpos((",".ValidatedField("page1_214","page1_214").","), "," . "3" . ",") !== false || "3" == "")) {
if (!(false)) {
<font color="#FF0000">Time is required</font>
<?php //WAFV_Conditional page1.php page1_214(3:)
}?></td>
</tr>
<tr>
<td>&nbsp;</td>
<td>&nbsp;</td>
<td>&nbsp;</td>
</tr>
<tr>
<td>&nbsp;</td>
<td><label>
<input type="submit" name="submit" id="submit" value=">>> Continue" />
</label></td>
</tr>
</table>
<p>&nbsp;</p>
<p>&nbsp;</p>
</form>
Thanks alot for the help
Jimmy Wu
If you are handling the forwarding at the top of the page, you can leave the form action blank, so the form will post to the current page.
What you can do is to post the form to a page and have that page check the value of the radio button and then forward based on that.
Walikan
Hello Jimmy,
I left the form action blank. Jimmy, I will appreciate if you can illustrate with a sample code. I am new to php and still trying to learn the language. The zip file in the previous post has all the files. Kindly use the files to illustrate what you meant.
Thanks alot for all your help
Jimmy Wu
I made a sample page that forwards to different pages depending on which radio button is selected. First the radio buttons' values have to have the page that you are forwarding to stored in them. Then you can check if the radio group is set after the form is submitted. Then you can just set the location to be the radio button value and it will forward. Here is the code for the page:
if(isset($_POST["RadioGroup1"])) {
header("Location: ".$_POST["RadioGroup1"]);
<head>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
</head>
<body>
<form id="form1" name="form1" method="post" action="">
<p>
<label>
<input type="radio" name="RadioGroup1" value="untitled1.php" id="RadioGroup1_0" />
Page1</label>
<br />
<label>
<input type="radio" name="RadioGroup1" value="untitled2.php" id="RadioGroup1_1" />
Page2</label>
</p>
<p>
<label>
<input type="submit" name="button" id="button" value="Submit" />
</label>
<br />
</p>
</form>
</body>
</html>
Walikan
Hello Jimmy,
Thanks a million. It worked as was expected. If one keeps buying Web Assist extensions, it is because of your relentless support. Your support team is doing a great job.
Thanks alot.
Jimmy Wu
Great to hear you were able to get it working. If you run into any additional issues, feel free to open a new thread.
