issue when item added to cart is >= 1000
Thread begun 1/10/2010 3:44 pm by sam308940 | Last modified 2/16/2010 9:02 am by sam308940 | 3641 views | 6 replies |
sam308940
I have an issue with any items added to the cart that end up being 1000 or more.
If i add 250 of an item to the cart and its $4 each its shown/calculated ITEM TOTAL is $1. anything over $1000 from my testing, looses the 3 zeros. so if its $2000 it shows as $2.
however, if i add 100 of item A and 150 of item B, the totals are calculated correctly. There is no error.
SO I have an issue that is related specifically to the calculting of the ITEM TOTALS ONLY, the subtotal of the entire order is fine.
Is there something I can do to fix this?
Thanks in advance
Sam
it sounds like you have some calculations in your cart that are causing the issue.
can you send a copy of your cart include file so I can take a look.
sam308940
Thank you!
the cart object you have sent does no exhibit the error you reported in the initial post, in the cart object you have sent, no matter what I set the quantity to for an item, the item total is always the price.
If i have an item that costs $4 and add it to the cart, then change the quantity to 10, the total is still $4. This is because you have changed the TotalPrice calculation to:
TotalPrice: [Price]
it should be:
TotalPrice: [Price] * [Quantity]
sam308940
hi - no this is correct
because i am calculating the total before it reaches the cart i set it up that way on purpose as i do not wany quantity changeable or even 2 of same item.
ie if someone purchases 500 of item $2, it passes to the cart as 1 item of $1000.
The description shows the qty.
if you go here you can see:
card_view.php?P=487&C=B&S=BM
BUT... you hit on something for me.
use the link above, and pick a quantity that will total more than $1000
(you dont have to enter anything on the personalize/second page-just continue)
you will see that after you add to cart, you get the error amount shown.
I also have an alternative payment page - this just passes an amount to the cart.
(enter any order # and any amount over 1000)
payment.php
when i use this to add to the cart, i DONT get that error amount.
im attaching the file here for that page that passes the price to the cart and gives an error.
anything that jumps out in my add to cart code?
(i realize this is getting beyond basic tech support as its my edited code....i understand if you cant help on this one).
I think for some reason, the comma in the price is causing the problem.
change the following line:
$ATC_itemPrice = floatval("".((isset($_POST["TOTAL"]))?$_POST["TOTAL"]:"")  ."");// column binding
$ATC_itemPrice = floatval("".((isset($_POST["TOTAL"]))?str_replace(",","",$_POST["TOTAL"]):"")  ."");// column binding
sam308940
THANK YOU
that worked perfectly
sorry i took so long to get back on this item
but i wanted to post that it solved the issue in case anyone else ever runs into it.
