discount code to only apply to items with weight of 1
Thread begun 1/10/2010 3:38 pm by sam308940 | Last modified 1/12/2010 1:36 pm by Jason Byrnes | 1759 views | 3 replies |
sam308940
I want to add a discount rule that only gives discounts to items that have a weight of 1
below is my current rule. I tried a few combinations of adding $this->Weight and $this->itemWeight ..... but it still just gave all items the discount. what I want is to only apply the discount to items with weight = 1, not just require that any item in the cart has a weight of 1.
//eCart Rule
function WAEC_pcccart_10NEW() {
$totalDiscount = 0;
if (true && ((sizeof($this->Items) > 0) && ((isset($_SESSION['discount_code'])?$_SESSION['discount_code']:"") == "10NEW") || ((isset($_SESSION['discount_code'])?$_SESSION['discount_code']:"") == "10New") || ((isset($_SESSION['discount_code'])?$_SESSION['discount_code']:"") == "10new"))) {
$totalDiscount += ($this->TotalColumn("TotalPrice") * .10);//Result
return WA_eCart_FormatNumber($totalDiscount, $this->ForceDecimalsC, $this->DecimalPlacesC);
//eCart Rule
dont add this in the code, add it when creating the rule.
In the Calculation section, select "Based on Items With a specific Value":
Total of "TotalPrice" Where "Weight" has a value of "1" "times" "0.1"
sam308940
OHH but we want to base it on a coupon code being entered.
so that the coupon applies to any items that have weight=1.
am I missing something?
if I do it your way, wont it give discounts to item with weight of 1 without a coupon code?
No, the trigger stays the same, In the calculation section, enter the calculation that I mentioned before.
