stuck on a file type filter
Thread begun 1/10/2010 10:16 am by gruant2000381341 | Last modified 1/10/2010 12:11 pm by gruant2000381341 | 2378 views | 3 replies |
gruant2000381341
I need some help, I am trying to set up a filter for an image upload. I want to allow jpeg,jpg,gif,bmp,and PNG
So far, I can only get jpeg,jpg, and gif........I can't get PNG or BMP at all. my code is below. I tried reseting the code to == "*.png" but that didn't work either.
if (($_FILES["file"]["type"] == "image/gif")
|| ($_FILES["file"]["type"] == "image/jpeg")
|| ($_FILES["file"]["type"] == "image/png")
|| ($_FILES["file"]["type"] == "image/bmp")
|| ($_FILES["file"]["type"] == "image/pjpeg"))
if ($_FILES["file"]["error"] > 0)
echo "Return Code: " . $_FILES["file"]["error"] . "<br />";
else
echo "Upload: " . $_FILES["file"]["name"] . "<br />";
echo "Type: " . $_FILES["file"]["type"] . "<br />";
echo "Temp file: " . $_FILES["file"]["tmp_name"] . "<br />";
if (file_exists("upload/" . $_FILES["file"]["name"]))
echo $_FILES["file"]["name"] . " already exists. ";
else
move_uploaded_file($_FILES["file"]["tmp_name"],
"upload/" . $_FILES["file"]["name"]);
echo "Stored in: " . "upload/" . $_FILES["file"]["name"];
else
echo "Invalid file";
anonymous
When you say you can't get BMP or PNG, are you saying they won't upload with the current code you have there?
If that is the case, make sure the files you are working with truly are bitmap and png files. I have seen several cases where the extension is not really what the file is. You may need to the check the properties of said files to ensure the MIME they contain is what it is supposed to be.
Best regards,
Brian
gruant2000381341
yes, that's what I meant. I can't get them to upload to the folder.
I right clicked>properties on the images and they are what I thought they were.
under general..type of file ..PNG File (.png)
under details..type of file ..PNG file
What could I be missing?
and I don't think it's a filesize issue...they are both under 500kb
I fixed the bmp part, but the png is still happening
gruant2000381341
update
well it has to have something to do with that one filter for png. I removed the filters altogether and now png's will upload....but I really want to filter that.
here's what I have now
else
else
