button changes colour with show regions
Thread begun 1/09/2010 5:42 pm by mr hankey | Last modified 2/23/2010 4:27 pm by Eric Mittman | 4557 views | 8 replies |
mr hankey
hi,
i am looking to have multiple results hidden on my page with a heading for each table to display.
basically they would click on the button and it would show that results however i want the button to be a certain colour if there is no data in the table so the user knows at a glance there is no point in clicking on button as no data will show and another colour when data is there to display.
hope someone can help i am sure this is a simple fix wuth dreamweaver but just getting my head around it.
many thanks
CraigRBeta Tester
possible solution
how's about using the show region server behavior with appropriate button if recordset is empty and different button if recordset is not empty
mr hankey
thanks mate for that,will that work with an accordian style effect menu where the content shows the details of a client?
so click on the link if it is a colour that say shows it has data, they click and it shows the products sold to the client?
many thanks
mr hankey
can you have multiple recodsets on a page for this to work?
cheers
When you use a show region you will need to specify a recordset to be based on. You can use this method to show one button if the recordset is empty, then show a different button if it is not empty. You can have multiple recordsets and show regions on the same page.
If you want to get this working with an according effect you should get that part onto the page and functioning how you would like it first. Then you can apply the show regions to show either the button with the according area or the other button.
mr hankey
thanks eric,
so workflow is:
1.accordian effect
2.recordsets
3.show regions
thanks again mate
Let us know if you have any problems with the show regions once you have the accordion effect and recordsets in place.
mr hankey
hi eric,
thanks for your help with this, i have the spry tabs effect in place now along with the recordsets and a repeating table in the content area of the tabs which shows if recordset is not empty.
this works fine however the tabs themselves i have as blue but i want it to be red if the recordset is empty how could i change this?
also eric i have created a page where the user can add a company name with product desciption which inserts fine into database.
how can i get it to take the product description and add into into a new tab automatically with a recordset creating from it along with an insert form?
i know the second one might be alot of hand coding so if it is tricky i might just change that page to a drop down menu and bind the menu to the product description column of that table but thought i would ask you anyway :)
thanks
In order to change the color depending on weather or not the rs is empty you can use php to dynamically add in a style like this:
if($totalRows_<your rs> <= 0) print("style='background-color:red;'");
This would go in directly into the tag for the accordion tab.
As for the second thing you are asking about I'm not very clear on what you are looking to accomplish. It would be a good idea to explain how things should work from the perspective of the user that will be interacting with this. I think this should give me a better understanding of the situation and what may need to be done.
