address markers are showing up automatically, but only on the live site - not local
Thread begun 1/08/2010 2:28 pm by sandy170299 | Last modified 1/11/2010 3:07 pm by Jason Byrnes | 3234 views | 7 replies |
sandy170299
Jimmy previously helped me disable the address markers from showing up automatically when a map loads, and it is working fine locally. However, when I uploaded my pages to the server, a default address marker is showing up again. The pages are identical - I just uploaded them to the server. What could be causing this and how can I get rid of a default address marker? I don't want to give one address more emphasis than another.
I'm still working on the site, but you'll get the idea: resorts.php?state=MN
there are 2 places in the code where you have the following:
if('address_0_0' == 'address_0_0')
marker_0_0.openInfoWindowHtml(address_0_0.infowindowtext);
change that to:
//if('address_0_0' == 'address_0_0')
sandy170299
Hey, Jason...
I don't have the code you are specifying in my file. In fact, I don't even have the marker_0_0 string. I have the following:
if(!fromAddress.enabled || 'address_0_<?php echo $getMap_id; ?>' != 'address_0_0') {
if('address_0_<?php echo $getMap_id; ?>' == 'address_0_0')
map.setCenter(point, 13);
map.addOverlay(marker_0_<?php echo $getMap_id; ?>);
map.setZoom(6);
So, what would I comment out? Yes, I have customized this to the point that I can't run through the wizard anymore because it will delete things that I've done. I can attach my file, if that would help...???
Yes please attach the map php file.
sandy170299
Attached is a text file of the map code. Can you please tell me exactly what you are changing because I have three separate map files that I will have to change it in.
There are 2 places where you have the following code:
marker_0_<?php echo $getMap_id; ?>.openInfoWindowHtml(address_0_<?php echo $getMap_id; ?>.infowindowtext);
change that to:
//if('address_0_<?php echo $getMap_id; ?>' == 'address_0_0')
//marker_0_<?php echo $getMap_id; ?>.openInfoWindowHtml(address_0_<?php echo $getMap_id; ?>.infowindowtext);
this will comment those lines out.
sandy170299
Thanks, Jason. Worked perfectly :)
no worries.
