Problem with the installation
Thread begun 1/08/2010 9:26 am by mdwarren28397701 | Last modified 1/14/2010 10:07 am by Jimmy Wu | 4836 views | 11 replies |
mdwarren28397701
I just purchased and installed Universal Email 3 on my Mac and i am getting the following error twice when i open Dreamweaver CS3:
"While executing onLoad in WAMemento_onOpen.htm, a JavaScript error occurred."
Then when i open a form and click on "Insert > WebAssist > Universal Email" i get the following error:
"While executing DWMenu_Insert_Webassist_UniversalEmail_WAUE command in menus.xml, a JavaScript error occured."
I tried uninstalling and reinstalling the extenion, but I still get the error.
Jimmy Wu
Try deleting your cache file:
mdwarren28397701
Deleting my cache resolved the error i would see when i opened dreamweaver, but i am still getting the following error when i click on "Insert > WebAssist > Universal Email":
Jimmy Wu
Could you send me the menus.xml file? It should be located here:
Hard disk: Users: <Your User Name>: Library: Application Support: Adobe: Dreamweaver 9: Configuration: Menus
mdwarren28397701
Attached is my menus.xml file.
Jimmy Wu
It looks like in your file, some characters were getting encoded when they were written to it. I am attaching a file that you should replace your existing file with. Let me know if that resolves the issue.
mdwarren28397701
I deleted the old file and replace it with the one you supplied, but i still get the same error.
Jimmy Wu
Which version of the extension are you running?
Is there a line number referred in the error?
mdwarren28397701
I am using version 3.0.7.
There is no line refereed in the error. I attached a screen shot of what i get when i click on "Universal Email".
Jimmy Wu
Try accessing Universal email through the server behaviors panel. Do you get the same error if you access the extension from there?
